Sweet. The bro does 2 on 2 off, auto sparky/electrician/diesel fitter. 160.000 per annum. He can troubleshoot anything. I have more respect for that man than any other tradesman I know. Cats Cummins mtus Waukesha wartzilla diesel gas locomotives power generation. He has a bedroom at home with dedicated model train sets on all the locos hes worked on. Animal
Sounds like a clever Kent. 160k isn’t that much for someone with so many qualifications and doing FIFO
I’ve got a restricted high voltage ticket aswell but I’ve never had to actually use it so I don’t have any experience. Hopefully I automatically qualify for a lot of the criteria so I can skip through the training easily
  • Like 1
22 hours ago, Beyond Blue R33 said:
On 21/11/2017 at 8:08 PM, R33kizza said:
I know how you feel, moved houae at the weekend and been doing 4 hours ot a day. Working 6am till 9pm tomoz..... fml
15hrs pretending to be a German might not be germain to the situation. Just try to avoid their porn. Sebastian vettel calenders everywhere :-o
10.5 hours ot in 2 days.... tired doesnt even touch it! However the 135i sat on my drive is kinda nice lol
  • Like 1
I sell things. :)
  • Like 1
Dad's mate had a e46 m3 man that n/a 6 delivered power beautifully. You know, when it wasn't broken down. Dave's nephew just bought a xr6-t out of the yard at midway ford. Dyno at 400rw/kW. Still on p's. Hope he lives to tell the tales.
Faster than a speeding bullet, moar powerful than a locomotive, leaps to air-conditioning in a single bound. It's that fat ranga welding guy.
Dunno if I could handle being in an office full time... too many muppets
Temporary Australian
  • Like 2
Lucky it's summer. Imagine the boost spooling up with the button off in the wet. I've busted traction 3rd to 4th in the xr8 and the skyline in mildly damp conditions. At least the Nissan is direct and pointy when having to pedal it. The falcon has lovels Springs Koni shocks and adjustable sway bars but is still the worst understeering dinghy ever. That massive 5.4 quad cam engine is a f**king boat anchor compared to the Windsor's I've owned. High front centre of gravity. Still the wife's favourite thing. Makes moar noise. Thinks shes a legend shifting at 4500.
Not reli a bmw fan but thr 135 is a twin turbo 6pot, 300hp and there reli light.... gd fun. The motors gd for 500hp on factory injectors and internals. Turbos not to much but its engine out to change them lol....
Id contemplated a fg xr6t to replace the skyline but there so damn heavy... 1800kg.... fat sloth
Heavy yes, but a couple mods and it's putting down 350rwkw. A few more and it's pushing towards 400. all without touching the stock turbo.
that barra motor is a heavy mofo but makes power so effortlessly.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
