No much worse, an Oil & Gas company that never stops production where every day lost is over $1m in revenue
Got the 3 days between for 10 days off. Have beaten the 2nd week of Jan deadline by 3 weeks yeah. Quoted 120hrs on job for Jan and got the job. Quoted 260hrs for another job in Jan and got the job. :-o hope the couch can handle 10 days of my fat arse on it. Do you want ham in those toasties, ham and salad roll, ham and ham with ham on the side?
  • Like 2
10 hours ago, turboedsloth said:
Going back to doodling Dale?
am already back doodling, thank fk
Still trying to get over the fact that they replaced the automatic espresso machine for a fkn pod thing
A FKN POD THING, PEOPLE!!!! THE REVOLUTION WILL NOT BE TELEVISED!!!!!!!
  • Like 1
We almost did that at work too!
  • Like 1
All modified skylines have coffee pod filter. Froths up the oil into the catch can and pcv valve for a sweet fuming blend of 7.5/35w. need a fmic for the one at home. Has been a bit sluggish lately?
  • Like 1
coffee pods are the devil. They have the WORST coffee in them - the one at work actually trys and uses the fact that it has robusta beans in it as a positive :cry:
Plus, the stupid amount of packaging waste they make is one of the things the next generation is gonna be pretty pissed about, and I cant say I blame them
Green pods are people.
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
