  On 16/01/2018 at 1:57 AM, turboedsloth said:
As are the black fresh water lobsters
Expand
are you coming on to me? because its working....
keen AF to get my hands on marron or crabs, due to not being able to hunt this season :(
I can put some in the freezer for you in if want? we are also going up Perth way on a sunday in the next 2 weeks apparently.
Went out last night, was murky as all buggery. Waiting for this rain to farkkk off before i go out again
  • Like 1
Expand
ken oath I would!!!! Also keen to catch up if you are coming up. Sunday WT lunch maybe?
I has a recipe for chilli lime and coriander crabcakes that brings all da boyz to mah yard.
  On 16/01/2018 at 4:48 AM, turboedsloth said:
Sounds like a date.
I can't do crabs. But marron, hhhhhhhhhnnnnnnnnnnggggggggggggggggggg
Expand
ooooh jeebuz. You turn up here with marron I cant guarantee I wont wrap my legs around your face. Its literally been years :blush:
  On 15/01/2018 at 10:13 PM, ElleAli76 said:
Hahahahahahahahah [emoji23] sounds like me & Dave ! We both bad with phones , gotta stop that tho
I usually only check the weather and Sau once or twice a day on holidays.
Delete Facebook, and you will thank me in a month when you realize how much spare time you have
  • Like 1
I can’t really delete Facebook, photos and business page all there [emoji24][emoji24]
  On 15/01/2018 at 10:10 PM, Stinky Rooster said:
Sunburn- sunscreen
Best sleep ever in our van...the beers prob help
Dirt- sometimes depending on location
Food- wife cooks as well camping as at home but menu choices are reduced
Scenery- sensational
thats some pretty flash welding there dude. Reckon I might hit you up soon for a foreigner [emoji14]
Thanks dale. MIG Welding is just welding, once the geometric pattern development is done I've already lost interest. Parallel, radial line and triangulation is the fun part for me :-) we finally have a bender arriving soon so. Exhaust manifold off, machined, sand blasted and painted with all new studs. Dual cai's, Ali coolant/dual motor washer bottle, pod filter box. Got bad hot air stacking under the bonnet. Would like to do Ali but might be stainless. Due to free bits from work. You know on top of the 50hrs I put in this week. Haven't used the turbo timer because intercooler but you can hear the manifold pinging under cool down. Don't want to go with lagging or blankets because it traps the heat in bad? Any thoughts?
Marc at C-Red reckon timers are pointless unless your racing, turbo blanket could be cool!
  • Like 1
Yeah my bro reconds the same. Switch it off while it's hot so the oil feed maintains pressure around the bearings. Dave said use it for now on Cool down because the manifold is warped and ticks bad for ages on cool down. Won't matter when it's fixed I suppose. Turbo/manifold blankets/lagging are a trade off because they hold the heat in which makes for less exhaust efficiency due to increased exhaust/turbo temps. Will do dual cai's. One to the original air box position, with the back open towards the turbo and one across the front of the engine toward the exhaust manifold through the hole that isnt used from front facing plenum. Will put heat shielding guards over the manifold and turbo that will hopefully keep the heat down to be blown out by cai's to avoid the stacking issue?
Have an industrial precision EGT sensor In my Ute. it drops from 350C to 160-180 in 20 seconds or so of idle or decel. Giving it another 2 minutes of idle time only gets it down to 150C so why bother.
Just back off for the last few seconds of driving and shut it straight down. Not being under load at the end the turbo will stop spinning relatively quick and thermal siphoning will help keep turbo coolish anyway.
Turbo timers are made to piss off the neighbours.
  • Like 2
I had a timer on the stagea, never actually used it for pretty much the reasons stated,
Also, I dont think heat retaining is an issue in turbos etc. its more the moisture the lagging traps, and how that leads to massive corrosion. Seen blokes do this to motorbike exhausts and they go paper thin within a year.
  • Like 1
most likely too busy chatting up 2nd hand military equipment dealers to bother with the likes of us
or, too busy trying to keep his dog from drowning itself at every chance. Seriously, it wouldnt even drink from my dogs bowl, unless BOTH front feet were inside the water dish - and my dog has a 40lt water dish....
  • Like 1
I had a timer on my old car, was built into the alarm. My car ticked and cracked once it had shit down, i thought it haf something todo with the fact the turbo and mani were cast, the downpipe was stainless and nuts and bolts were mild
  • Like 1
oh lawd
turns out "bring your kids to work day" doesn't really work when you are counting on engineers telling them what they do, to be enough entertainment and stimulation for kids. My normally quiet office currently sounds like a day care centre that has been accidentally hosed down with red cordial and dexxies.....
damn breeders.......
  • Like 1
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
