1 hour ago, Beyond Blue R33 said:
Check it out. 6 from 12 studs snapped under ring spanner back and forth careful arm pressure.centre popped and easy outed all fully drilled, tapped and ready for new genuine nissan studs washers and nuts. The manifold was so warped it was ridiculous. It's in being Re-faced now. Butter bolt studs and rattled up I reckon. Madness.
Sounds about right, proverly been off befor and supercheap studs fitted! Check this out, complete clutch basket failure on 1 of our drag bikes (i now crew on 2 cars and 2 bikes lol) iv never seen it ever.... all the fingers are gone lol
  • Like 1
Looks like it was machiened on a lathe. Haha. Mental
I heated mine up white once when it had a problem and it was distorted about 10mm across faces
Had to get another one
  • Like 1
Paid with more work and high expectations?
  • Like 1
Labour of love, engine rebuild and some light fabrication to fit a turbo to it [emoji48] 8.50s here we come
You're a animal. [emoji882] top of the line German to drag 2 wheel 4 wheel jap and everything in-between. Big Jobs. I've been stuck inside the belly of the beast. Madness. Slowly but slowly. Pulled the last poxy bolt with 3x extensions and a uni joint on the rattle gun that was hidden away drilled and tapped into a I beam across the chassis rail. Ffs.DSC_0187_2(1).JPGDSC_0177_3(1).JPGDSC_0186_2.JPGDSC_0183_4(1).JPGDSC_0194_4.JPGDSC_0196_3.JPG
On 04/03/2018 at 8:49 PM, Beyond Blue R33 said:
You're a animal. emoji882.png top of the line German to drag 2 wheel 4 wheel jap and everything in-between. Big Jobs. I've been stuck inside the belly of the beast. Madness. Slowly but slowly. Pulled the last poxy bolt with 3x extensions and a uni joint on the rattle gun that was hidden away drilled and tapped into a I beam across the chassis rail. Ffs.DSC_0187_2(1).JPGDSC_0177_3(1).JPGDSC_0186_2.JPGDSC_0183_4(1).JPGDSC_0194_4.JPGDSC_0196_3.JPG
f**k that for a laugh, looks like a right twat of a job lol
  • Like 2
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
