My latest multi meter was run over by a Ute months back and is now starting to tell lies. Might order a newbie tomorrow
Every time I go to contract power/mtu/cat/Detroit/speno rail there are blokes running with fluke meters. The bro swears by them.
3 hours ago, hattori hanzo said:
Anyone used any panel and paint shops for a complete glass out panel off respray they have had a good experience with?
Vulcan panel and paint in canninton would be my option. Depends on where u are and what u wanna spend!
Did this to my snapon one a last year, didnt work after that.... snapon wouldnt warrant it either ?
Flukes are good, but so are many cheaper options. I’ve had 2 flukes that both got run over, a dick Smith jobbie that still works well, cabac clamp meter that’s still good and just about had enough of my sidchrome meter.
Cat meters are ok but like many meters they start to lie before the battery warning comes up
  • Like 1
I just bought a sp tools 1/2" mini rattle gun and 1/2" air ratchet and wish I hadn't. Should have gone the Ingersoll rand. But very expensive. :-( the sp's look like a re-baged shinano. I only got 2 yrs from the last sp 1/2" ratchet. Boss replaced it for free because I was pissed off. I just bought a full set of gear wrench metric and imperial ratcheting spanners and they are sweet. I also bought a full set of gear wrench long combination spanners metric and imperial which kick ass. Compared to all my old sidcrome stuff. Going out at cost from beyond tools in Malaga. Doing more fitting than fabrication these days. Shame I'm the only person in the shop with the correct tools. It's annoying.
12 hours ago, t_revz said:
O-rings you say?
Which ones?
OK, so you have these bad boys running through the firewall
peugeot-205-1.6-1.9-gti-xs-heater-matrix
which connects to the heater matrix as thus
and if you notice the 2 black clips halfway between the firewall hard tube, and the heater matrix, you get to these suspect little f**kers
and these are the issue (I suspect)
they are located in the drivers footwell, and I am pretty sure they will be accessible just by dropping the bottom off the dash (and maybe yoink the shifter) but given I cant get into the footwell to eyeball any of this, its all purely academic at this stage. It might be a shat heater anyway :/
peugeot-205-1.6-1.9-gti-xs-heater-matrix-water-pipes-alloy-with-clamps-296-p.jpg&key=6403632e1cf8687cb68b95cb44038161ddfb869e0adc845cfcc30c2cb790d7ac
317474A.jpg&key=daac6438defd1859ee441f59ce27cb09012791bbf7045b7a8f64091934c6a1d6
s-l300.jpg&key=165a51c40b6fd0734e096ce670c90f1a606f2d9cfc0cc02053d2eff3203bc178
they are located in the drivers footwell, and I am pretty sure they will be accessible just by dropping the bottom off the dash (and maybe yoink the shifter) but given I cant get into the footwell to eyeball any of this, its all purely academic at this stage. It might be a shat heater anyway [emoji32]
So many o-rings
What stupid Kent’s
If you can stomach the brand name tax that comes on the fluke gear. You rarely get a shit product from them.
  • Like 1
I know, right?
Plus, if it is the o-rings, it means my u-beaut nulon coolant is a POS
Do you have a air compressor at home? You could test the send/return from after the poxy o ring arrangement to see if it holds pressure before pulling it out. Which is a prick of a job. You would think after only 100,000 the core would be fine if it's always run inhibitor/coolant? You could also run some soap suds water through it under pressure with the tubes attached to check the poxy o ring arrangement?
Quick google looks like focus are notorious for leaking heaters
  • Like 1
Agreed but in the conditions I work in I’d rather 3 cheaper meters to a same level fluke. I work in the rain, mud, grease and whatever else is thrown at me.
  • Like 1
On 14/03/2018 at 7:02 PM, Stinky Rooster said:
I know, right?
Has it ever had a coolant flush? Different coolant colours have different additives to stop issues like this
  • Like 1
I've been using Nulon Coolant for over a decade in Multiple performance cars (Red or Green) with no issues what so ever. Top coolant in my opinion :1311_thumbsup_tone2:
Currently use the Green in my 32 GTR and Red in my R8 Maloo.
Edited by Anonymouse
Update
If you need parts my mate is a service manager at Ford. If you can't be assed chewing out the stuffed old back I could put a good word in for you to get it fixed:-) p.m.
Spotted a sweet looking yellow r34 on the Tonkin today. Gave you a thumbs up if you are on here ha ha
Hey dude hows the gt-r running? Looks like a good investment the 33's are starting to sky-rocket bit like 32's and 34's. Except it looks heaps better[emoji41]
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
