Dale! Angie sent me a bunch of pics from the weekend, I'll get them through to you.
Yeah, I agree, I think we won on our epic BBQ - Dale even got a fkn medal!!!
I think overall (laps wise) we came around the 5th mark.
Plans are already a foot for nect year, Dale is even going to help drive!
5th is pretty good
No major issues?
5th is pretty good
No major issues?
If its blowing fuel pump fuses its gotta be the fuel pump shagged. Foes the car sit for long periods of time? Australian petrol has a % of water in it which leeds to fuel pumps siezing when they sit. Common problem for bmw motorcycles.
16 minutes ago, z00key said:
38 minutes ago, Hank Scorpio said:
Ugh, old mate no-paypal is giving me dramas. Fk, I don't wanna have to find these damn parts again!
try this quote "im kinda a big deal in Australia, I have meny leather bound books!"
Haha! I'll try that for sure. Luckily I've made a couple of contacts over there, we will see what happens.
^ This also means I need to go back to the States in a couple of years, this time - Texas!
Dale - Going to reverse sear a couple of Secret Butcher rib eyes for the parentals saturday night for looking after Hank. Mum can't cook a steak to save her life, so I think they will really enjoy it!
Wondering what to do with my Monday off though, do I fire up the GMG? What do I cook?
Dale! I'm also working on a new Lemons sponsor for next year. The driver they will nominate (if it goes through) will also be a handy 3rd pitmaster. This means we load up the GMG, maybe try that brisket?!
you NEED a sous vide bro
I may never reverse sear any other way, ever again :P
And I am keen AF to get the offset down there next year. The "set and forget" aspect is looking pretty damn attractive if we are going to do brisket.
Plus, burnt ends!!!!
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
