Like most problems in life, the answer to this, is coffee!
Srsly, its why they put bowls of coffee beans on perfume counters in stores. If your nose stops working properly, have a big sniff of some coffee beans, and it will wake right up again.
Unfortunately, this is not recommended here. Losing smell at work is a good thing.
The burgers at the canteen are pretty tits though.
also YAY FKN FRIDAY!!!
Yeah Friday. I finished at 2:00pm and finally have a Saturday off[emoji28]. Used a full 15kg of mig wire in 4 days.[emoji26]mms_20190109_191709.jpeg
  • Like 1
Bitchezz... what’s a cracker nursery in Perth that might have hard to find seeds? After a type of mint from japan which is permitted here but can’t find a stockist yet and eBay sellers won’t post to WA or TAS
Trev - I am a big fan of guilford nursery.  They do heaps of edibles and have an awesome staff that know everything.  They also do pretty good blueberries.
Corey  - at Kwinana but apparently I will be gracing pinjarra from time to time.
Tried them first dale as I’m a regular there but no response yet. Might get them sent to sister in Darwin then she can send to me sneaky sneaky
good luck with it bro. I know the pain of getting seeds to WA.
Last time I drove through the WA border, the guys on the front line were way more interested in the apple in the cab, than they were about the 15kg of smack in the back of the truck :D
  • Like 1
holy shitballs the roads in this city are treacherous this morning. Take care out there people!
Hit a load of dropped detergent on the way to work. Had a (thankfully very switched on driver) watch me slide completely past the bonnet of his car this morning, trying to make a turn, road turns to polished glass and all of a sudden I am going straight, despite almost full lock on the bars and about 25 deg lean. Pretty sure they heard my arse clap shut in Bunbury. NFI how I managed to stay upright and miss the car waiting to turn, but I am pretty sure it looked cool AF so that was nice....
Lol did it though it did it look more like a giraffe learning to walk [emoji6]
total crossed up speedway slide with me on top of Ragnar The Yamaha?
Nah, it looked cool. How could it not?
The scene inside my helmet/pants? Probably not so much.
  • Like 1
I was wondering what that Boom was...
Sounds like we had an opposite experience.
Took 3 laxatives in succession yesterday for surgery today. My ass blew open in the arvo and didn’t get a rest til 1am
  • Sad 1
sounds like a good time was had by all!!
Hope the slice and dice session with the vet isnt for anything srs.
If they have any left over bits, hook a brother up?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
