You'll find that the stock ECU starts to struggle long before the turbo itself is in danger (it will run to 14psi plus....probably....)
The stagea ECU is very conservative and will quickly run very rich and reduce the timing; you will notice this as more boost not making it go faster....and lots of black smoke.
So....if you want to run more than about 12psi you are going to have to do something electronic anyway (eg new computer or SAFC or fuel cut defender)
Here's 2 graphs from my car in the old days.....red line is stock (top line is power, dotted line is boost). black line is after installing a fuel cut defender.
This graph shows why the power goes down like crazy; the stock computer was dumping in heaps of fuel (running rich) to protect the engine from what it assumed was an issue....see dotted red line which is the air/fuel ratio on the stock computer.
  • Like 1
https://www.sau.com.au/forums/topic/456628-stock-turbo-psi/#findComment-7534150
Where did you hear that info? Your Mum.
Why do you doubtimg it? Your Mum talks some shit.
Are you new to the internet? No, unfortunately I'm not. I do however see as to how you may have been confused regarding my prowess. Given I joined a topical forum, located the relevant Stagea discussion pages and I tried to make a general inquiry about said stagea like a tots newb. lol ;) #twat
Your not the first to raise the boost on a stock turbo. & I wouldn't be the first in given ya Mum some pounds per square inch either. (Tip: that's like a quite a lot, more than 3 bars even).
https://www.sau.com.au/forums/topic/456628-stock-turbo-psi/#findComment-7534207
Thanks mate for your helpful response, I noticed that the modest increase I gave it didn't necessarily equal the expected returns. Can see why this may be the case now.
https://www.sau.com.au/forums/topic/456628-stock-turbo-psi/#findComment-7534210
I like the way you say you aren't new to the net but failed a quote edit.
Anyway, as Duncan kindly provided, and you figured out, just raising the boost on a stock ecu really isn't goiin to provide fantastic results.. As has been mentioned numerous times before.
https://www.sau.com.au/forums/topic/456628-stock-turbo-psi/#findComment-7534243
So....if you want to run more than about 12 psi you are going to have to do something electronic anyway (eg new computer or SAFC or fuel cut defender)
Had another look at your graphs and finding it a little odd that the fuel seems to drop so drastically (pre FCD) on basically the comparatively stock perimeters. While the Blue line is displaying a more even and greater power curve the two PSIs remain pretty equal. I would have assumed that at around normal performance the ECU/Injectors should be able to maintain load?
While I am not noticing any black smoke running at 10 psi, you mentioned that this may be because of the ecu retarding the timing & loading extra fuel, leading to injector failure. Wouldn't this extra fuel mean that it would be capable of simply providing the extra requirement? or is that the injectors are not able to maintain that load and essentially fail?
Is there any short term benefit to insure the exhaust flow is in turn increased, dump-Cat-mani-exhaust etc? Otherwise it appears that a ECU tune is really the best option.
https://www.sau.com.au/forums/topic/456628-stock-turbo-psi/#findComment-7534678
Yep that's exactly the point....the stock stagea ECU is very conservative and does not like extra boost. FCD was a cheap and dirty fix, something like an SAFC would be a better idea for a car that is going to stay reasonably standard. Whole ECU replacement is a couple of grand no matter how you go about it.
https://www.sau.com.au/forums/topic/456628-stock-turbo-psi/#findComment-7534731
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
