Hey guys, just Oced my 4790k to 4.7GHZ which only seems to be stable at a constant voltage set manually rather than one set by an offset. Wondering if this will result in a heavy amounts of power usage?? I couldn't find a straight answer on google, so thought id ask here, im sure theres a few tech savvy people ;)
Oh and also, will the constant voltage degrade the chip??
Voltage = 1.28v
temps max = 77c during stress test
idle - 28-33c
During GTA V = 69 c
Speedstep is enabled.
Cheers guys!
Edited by Deza3000
Anything under 1.3V is considered safe for regular use of an i7.
The stock voltage of one of the 4790K variants is actually 1.273V @ default clocks.
1.28V is good (lower than average voltage) for a stable 4.7ghz OC on the 4790K.
You can expect a higher power draw at overclock than stock, but maybe not as much as you would expect.
Taken from Anandtech (http://www.anandtech.com/show/8227/devils-canyon-review-intel-core-i7-4790k-and-i5-4690k/2)
  • Like 1
Oh too easy! Thats everything i wanted to know :) Cheers for that mate!
What setting are you using to adjust CPU voltage in the Bios? Normally adjusting the CPU core voltage manually to say 1.28V will mean a variable voltage with a maximum of 1.28V. I would suggest lowering the clock to 4600MHz and using the CPU core voltage adjustment to set voltage. My CPU is a dodgy clocker, It takes 1.3V for a stable 4600MHz clock
Below are my overclock settings for what was stable for a month until I changed settings higher.
EIST: OFF
Turbo: OFF
CPU Multiplier: 46
Base Clock: 100
Core Voltage: 1.3V
I overclocked my memory too but no need to list that as yours will likely be different.
My highest stable settings so far are as follows;
EIST: OFF
Turbo: OFF
CPU Multiplier: 49
Base Clock: 100
Core voltage: 1.44V
VCCIN Voltage: 2.2V
CPU SA Voltage: 1.2V
I just De-Lidded my 4790K and I immediately went back to square one with overclocking. It would not load at over 4600MHz so I'm in the process of overclocking to 4900MHz again!
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
