Located In Ballarat VIC
Will post most parts at Buyers expense
****RB30 Parts****
R31 Auto Gearbox Computer (Located under passenger seat)
-A64-000 J29 $10 ono
-A64-000 J41 x2 $10 each ono
Charcoal Canister $20
Power steering Res $20
O2 Sensor x2 $20 each
Idle Air adjust with FICD $20
Pressure Reg – Solenoid Valve $20
Auto Throttle Position Sensor $5
Air Reg x2 $10 each
Factory Water inlet and out block fittings (Rad hoses connect to) $5 each
CAS(Crank Angle Sensor) x2 $10 each
Coils x4 $10 each
Pressure Reg $10
Throttle body x2 1Missing the Throttle cable connector $10 each
Dizzy x2 $20 Each
Throttle cable holder Block bracket $5
Starter Motor x2 $25 each
Alternator $25
Fuel Pump out of Cradle $20
****Outside Parts****
Chrome Door Handles – All Except Drivers Side $40
Black Door Handle – Front Passenger side $10
Bonnet Hinges Both Left and right $5 each
Fuel Cap $5
S3 Headlight Drivers Side $25
S3 Headlight Passenger side x3 $25 each
Front Bar Indicators – Both sides $10
Chrome Strips that go above the top of the doors – both sides $30
Side Indicators – Both sides $10
Wagon Drivers Side Tail light $10
Wagon Passenger Side Tail light – Small Crack $5
****Interior Parts****
Ash tray - $5
6 Gauge Cluster x2 $30 each
Pintara cluster (Clock where the rev gauge is) $10
Random Brown interior – Too much to list – Let me know what you after
Random grey dash buttons - Let me know what you after
Grey dash - $20
Brown Dash insert S3 TI (The whole thing the dash sits in) $50
Indicator/Headlight stork x3 $20 each
Wiper stork 1x Adjuster $20 x1 Non Adjuster $10
https://www.sau.com.au/forums/topic/456638-r31-skyline-rb30-parts/
  • 2 months later...
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
