Most times they should start and idle but run like shit, I've had one that would not run at all, if you have access to known working one then its a piece of piss to eliminate that from the equation.
Cheers, I'll give it a go, got nothing to lose haha
Problem found. Injectors were not flowing properly even though they were supposedly checked by a workshop... Got a second opinion and problem solved. I can't believe 3 injectors stopped flowing at the exact same time, what would cause that?
Anyhow, now I need to set idle and timing on my auto A31 RB20DET.
I've done a lot of research on this site, looked up info from the manual and stickers under the hood, but I'm still a bit unsure about a few bits.
According to the sticker under my hood, idle and timing needs to be set to 700rpm @ 20deg BTDC.
Setting RB20DET idle:
Engine needs to be at normal operating temp.
Shift lever to 'N' position.
Make sure all accessories are of.
Idle needs to be set to 700rpm.
Simply disconnect AAC valve and turn idle screw appropriately to set.
Then reconnect AAC valve.
Here are some things I'm unsure about:
I've read a few things in regards to adjusting idle with the ECU screw. When and why does this need to be done?
Also, the way I understand it, the AAC valve is only in use under certain circumstances, eg. AC or headlights are on, steering wheel turned, etc. So that would mean normally it would not be in use. Therefore, after setting idle to 700rpm with AAC disconnected, then reconnecting it, the idle really shouldn't change from 700rpm unless the AC was turned on, or anything else that engages the AAC?
Setting RB20DET timing:
I know how timing is set, but there are a few little details I'm unsure of.
Is timing also set at N 'position'?
Is timing set with AAC connected or disconnected?
What about the TPS, is it meant to be connected? The manual says nothing about disconnecting it, but I've read a number of people saying it should be disconnected when setting timing?
Finally, before carrying out any idle or timing adjustments is it important to first check and eliminate any air/vacuum leaks, as well as, making sure the cold air regulator is properly opening and closing?
Sorry for the long post, but thank you everyone for your help.
Have a top weekend!
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
