I have Peavey Studio Pro 112 (single cone... Like 1 speaker or whatever you call it) amp and an AXL Amp Rapture Series quad box - http://www.axlguitars.com/aarap100hr412c.html
There are better ones out there but this only cost me $750 with the Head and Quad box. + I run my guitars through a Boss Metal Zone pedal anyway.
nice setup!
do you use any other effects besides the metal zone?
  • Replies 100
nice setup!
Hah!
I would love to own the whole BOSS Pedal series, like how they put it on display in the music stores.
But I would probably only use a few but anyway.
I only use the Metal Zone atm, I was thinking of buying a few more Distortion Pedals... BOSS make a Turbo Distortion Pedal, but I figured the Metal Zone can replicate that and a few other pedals so I have just stuck with that.
The Metal Zone can replicate a Fuzz, Overdrive and various Distortion Pedals + a few more pre-set settings... So it is kinda like a few/multi pedals in one.
Gota friend who's got a V-Amp effects unit and it contains probably over 100+ effects... You can sit there all day playing around with it.
Hah!
yeah i have a korg AX1500G effect processor but only use it for practice and song writing... for gigs, rehersal and recording, i have 2 x distortion pedals - a vox cooltron bulldog and a mxr distortion iii... gives me a bit of variety... i don't use too many effects, i have delay, chorus, compressor, wah... i also have a tuner with mute and a noise supressor... pedal board was a bitch to make! i'm sure if i had the $$$ i'd go nuts and buy heaps of different pedals...
Edited by Evil
I use a POD :P 30 amps in one.
i hear they're pretty good...
although i am not the biggest fan of tone modelling and multi effects... i used to love it but found i could get better tones mucking around with a few pedals...
Well it's a proper amp simulator. I pick an amp (say a nice Mesa Boogie) and then I pick a cab (ranges from small practice amps to huge 4x12s), set the gain and EQ levels, then I go straight into my recording interface.
If I was doing gigs then I would use a real amp. The POD does a very good job though. A lot of qualified audio people haven't been able to tell the difference between my POD and an amp.
How do you find the KORG, VOX and MXR effect pedals as apposed to the BOSS products?
Or are they pretty much the same..?
The KORG AX1500G would be fun to use.
Different sounds and effects can help a lot with song writing as it also brings out a lot of interesting sounds, which you can make into a song.
+1 for Metal Zone
wouldn't mind a nice delay pedal though
+1 for Metal Zone
Digital Delay would be sic for echo effects!
Flanger Pedals are fun.
Any of you tried an Acoustic Simulator? Does it really make an electric guitar sound acoustic?
Nah, not overly. I think it brings out the warmth of an acoustic but nothing can replace the true tones of an acoustic guitar.
Yeah that's for sure, I guess it save you from bring 2 guitars everywhere.
Still the best acoustic sound is from an acoustic guitar.
i love the vox and mxr pedals :P i have some boos pedals...
most of the boss are digital and have buffered bypass whereas the vox and the mxr have true bypass and are analogue... but they are all great... boss dd3 is a fantastic pedal!
the AX1500G is really good for practice (headphone jack means you don't need an amp)... some good effects and poor mans POD type amp modeling...
Whao! :P
That's some awesome equipment there!
"most of the boss are digital and have buffered bypass whereas the vox and the mxr have true bypass and are analogue" - How do you mean digital and true bypass?
Does that effect the sound of what the pedal will produce through your amp?
Whao! :sick:
buffered bypass is a circuit within guitar pedals that attempt to remove tone suck when the pedal is switched off. this is done because if you have lots of pedals in a chain, the signal can get weaker and the sound can be tanrished.
in true bypass, when the pedal is off, it's like its not even there.
as for digital and analogue, digital pedals can sound a little artificial, not all of them boss make excellent digital pedals (DD-3 being a prime example).
Good example of this is can be shown just by plugging a cheap effects pedal in without it switched on...the sound is noticeably different to plugging your guitar straight into the amp. Even on a 10 watt practice amp :sick:
Right I see...
Thanks for that!
Good example of this is can be shown just by plugging a cheap effects pedal in without it switched on...the sound is noticeably different to plugging your guitar straight into the amp. Even on a 10 watt practice amp :)
100% correct! tone sap is a big issue. so is level reduction...
Right I see...
Thanks for that!
no worries! i learnt a lot of stuff talking to other musos... i am still learning stuff...
Ok one more time... Haha!!
Most BOSS Pedals have a buffered bypass to reduce the tone suck, hence not tarnishing the sound = Still keeping a very Clean Channel sound when the pedals are off.
Ok got ya!
Cool! :)
Don't need one :)
Benefits of having a strat copy with a 5-way pickup selector and no humbuckers! On the 2nd and 4th positions most people can't tell my guitar from a recorded accoustic!
I reckon all the guitarists on here should have a solo/riff competition, where you record 15 seconds of sound and post it up. Don't know how judging would work though :S
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
