Kaaz if you're prepared to invest $$$ in it, otherwise a spool. Mini or Full.
The stock LSD Centre isn't much to write home about. You can have them rebuilt, but the cones wear pretty damn fast.
Is it an auto or manual diff? If auto, it has the 3.9 CW+P, you can go to pintara 4.11 gears,
if it's a manual, you can go to either R31 3.89, or piny 4.11.
You have to have it all apart to do a centre, so may as well do it once.
There's VL Turbos running 8's on slicks and 28 spline axles, so for a big power 30DET... personally i'd run a full spool and OEM axles (Moser billet axles aren't too expensive) and 4.11's depending on the gearbox. You're setup may like 3.89's.
Just my opinion. Hope that helps.
https://www.sau.com.au/forums/topic/456662-r31-rear-end/#findComment-7535462
hey r31 drift pig thanks for that I will look in to a full spool and oem axles and yer it on it third auto diff manual one had to get here in nz and at the moment it has a rb20 det box in it but just got a big box r33 25det ( get rebuild ) thanks for the help
https://www.sau.com.au/forums/topic/456662-r31-rear-end/#findComment-7535555
Just an FYI... OEM axles mean the stock ones. OEM = original equipment manufacturer. Your reply sounded like you thought it might have been a brand or type.
If you're on you're third diff... maybe a set of moser axles would be the go for you. Get a 31 spline spool and matching set of mosers, with a 4.11 CW+P, would be pretty much unbreakable.
And you'll be getting a tailshaft made for the 25 box, so may as well get a bulletproof shaft done as well.
https://www.sau.com.au/forums/topic/456662-r31-rear-end/#findComment-7535586
lol yer figed that out pretty quick haha
A mate can over yesterday avon and said he as got a full rear end out of a ss vl that is a 28 spline and lsd do u know if u can swap it round to work he said ya can but do not know
ps just trying to find a little bit cheaper way :-)
thanks euan
mmm just was talk to my boss who done his apprenticeship at black well holden he dose think it will work ??
and I have never seen a pintara in nz did they come here or are they just rear????
Edited by r31 wags
https://www.sau.com.au/forums/topic/456662-r31-rear-end/#findComment-7536196
VL LSD is still cone type, which, even when rebuilt, will wear out pretty quick, and you're back to square one. Been there done it. Not worth the trouble.
My recommendation is still a spool, stock axles, and gear ratio to match.... KAAZ LSD/Harrop true-tracs's are at least $1200+, probably another $500 to fit... plus all the other consumables like bearings and seals, and a CW+P if you wish to change that too.
You've got a $2500 diff by that point. Mini spool for $75, $100 on bearings and seals, leave current CW+P and have it all assemble and cleaned up and be under $1k
I ran this exact setup in my R31 track car and it was faultless..... came out and was sold when I transferred my running gear to a HR31 coupe and is still running great.
Up to you now where you want to spend the $$$
Unsure if pintaras were release in NZ, but you can buy the CW+P's cheap enough on ebay that even if you have to have them lapped and cleaned up, they're still worthwhile. Seen them for around $200 + post.
https://www.sau.com.au/forums/topic/456662-r31-rear-end/#findComment-7536445
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
