Just went to autobarn and ordered one in. The bloke who sold it to me made a big mistake. I know where he lives. Hope the new one fixes the problem. If not I will be pissed off big time. After I got the old one to seal better and took it for a drive. It felt a lot more responsive.
That's good you sorted it out.
he may be in the same position you were in at the beginning, and have no idea it's a fake.
Bought second hand. But un used paid 350. Has all the turbosmart writing and emblem cast onto the main body
Saved $50, but was it worth the headache? :/
Those Chinese will copy anything... Poorly.
Well, tell Turbosmart. When i bought a replacement i grabbed two ... expecting it to fail again
http://www.turbosmartdirect.com/Product-Categories/Previous-Edition-Wastegate-Parts/WG-Valve-Guide-O-Ring.html
Item Name/Code Qty Brief Description Rate Amount
TS-0501-3004 2 WG Valve Guide 'O' Ring $4.50 $9.00
Well replacement one fitted. Fixed the problem. The old one is different from the one I got today. Easy way to pick it it the size/tthickness of the flange. Chinese copy one is about 2 to 3mm thick and the real deal is 5mm. Pain in the arse as I have a Chinese flange welded on the exhaust housing for the gate. Have made a spacer to go in the v band to hold it properly.
  • Like 1
