Quick update for you guys
Been flat out at work and I'm also in the midst of organising the remaining parts for the tune and also the tune itself
Been chasing up tuners etc trying to get everything falling into place car may be tuned on e85 aswell! Trying to sus out a dual map
Quick question for you guys
The paint scheme for the car was flat orange with a black bonnet and boot
As well as flat black wheels with an orange lip
Due to very much foreseen circumstances it's going to be a while before this goes ahead
Had the idea of rattle canning it flat black and orange wheels instead till the real paint comes...
Please bare in mind it couldn't look any worse then the car already does
This showed up today as well there was a second box same person sent on the same day at the same time but it didn't arrive. A little worried. It was containing the rear lower control arms.
It will be getting all the suspension components installed and drift alignment very shortly.
Any suggestions?
Was thinking
3.5 in the front
Max caster
4 mm total toe
0.5 in the rear 0 toe
Is there a certain setting for the traction rods?
And I figure I may aswell update you
Current mods
NI indicates it's yet to be installed
INTERIOR
Mods
Bride seat fitted to drivers side
Nrg short hub and quick release
Nardi deep corn wheel
Dildo shifter
Drift button
Replaced
Shifter boot
Handbrake boot
Sunroof assembly
Yet to do
Replace passengers and middle vents
Replace heater assembly
Order and install bride zeta iii seats drivers and passenger side
Replace door trims
Replace carpet
ENGINE
Mods
Splitfire dis001s NA
Z32 afm + tomei plug NA
Apexi pod NA
NISTUNE Ecu NA
OP6 turbo NA (may buy a different turbo)
Replaced
Temp sender
ECT sensor NA
02 sensor NA
Coilpack harness NA
On order
Hdi front mount
Walbro 400l pump (e85 compatible)
Deastchwerks 900cc injectors (e85 compatible)
Possibly a different turbo
Metal intake pipe
HANDLING
Mods
Silvers neomax coilovers all around 10kg front 8kg rear
Adjustable front upper camber arms NA
Adjustable caster arms NA (currently stock new bushes)
Adjustable front lower control arms NA (currently running r33 Lcas)
Rear adjustable upper camber arms NA
Rear adjustable traction rods NA
Rear adjustable Lower control arms NA
Hicas eliminator kit
Front strut brace
Replaced
Front wheel studs
Caster rod bushes
BRAKING
SWEET f**k ALL BRAKES ARE SHIT AT THE MOMENT!
Hope that gets you up to date with what's happened to the car since the start of the thread
  • Like 1
  • 3 weeks later...
Some "semi" good news
The skyline is no longer my daily.
I sold my rx7 weekender and bought a more suitable daily
This is bad because I'll miss driving it everyday....
But does mean no defects for me during work days and I can also save some cash which I can pump straight into the skyline
And also run dedicated e85 and a slightly bigger turbo as street drivability isn't really priority anymore
Here's the old girl being tucked away for a while post-108512-14362703886068_thumb.jpg
Cars probably getting painted on the weekend hopefully as long as everything goes to plan
Haven't been able to do much due to money issues and a few set backs
Was suppose to be painted last weekend but yeah
Hopefully things will pick up
Finally picked up my guards off Ianmack thanks heaps again dude they look awesome can't wait to get them on
He also helped me out with a fuel tank as my old one still leaks
A couple of things arrived in the mail
Gizzmo msibc is one
And I took a trip to rocket finally to get some gauges
Also after having only drive the lancer for 2 weeks
I loved getting back in the 32. Was amazing
  • Like 1
  • 1 month later...
Hey sau
Been FLAT out at work and things lately and having the lancer as a daily I got a tiny bit lazy with the skyline and I even lacked motivation last weekend but a quick drive and a little sideways action put me back on fire and I actually took it out for a drive with the dash all back together and now the cabins exactly how I wanted it
I also have a new fuel tank (to fix the leaky one) and my walbro 460l showed up ready for the e85 [emoji108]
I also finally got my drift crew stickers cut up
So let's take a look at the before and afters of my dash
Yes the old drift boost gauge is available for anyone
Before
After
Note gizzmo wasn't put in. But all the wires there just gotta choose where I want it
Ultra bright white smd lets through out
Autometer guages installed
Boost water temp and oil pressure
Here's a couple of shots of the progress and wiring etc
Just to fill up the post I guess as I said things have been slack
post-108512-14402643038758_thumb.jpgpost-108512-14402643335305_thumb.jpgpost-108512-14402643533342_thumb.jpgpost-108512-14402643901005_thumb.jpgpost-108512-14402644201605_thumb.jpg
yes the bottom 2 stickers arnt straight I'll fix that one day post-108512-14402644646672_thumb.jpgpost-108512-14402644859716_thumb.jpgpost-108512-14402645274864_thumb.jpg
First folder got full of receipts so we're onto the second folder came into play
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
