Living With An R33 Gtst
So its the time of the semester where every assignment is due, also exams are coming up so time spent on car has rediced significantly.
After submitting a major assignment today, I thought i need a break.
I bought some GKTech 50mm long black wheel nuts and came home to find my steering wheel cover delivered.
So first were the wheel nuts.
Wheel nuts installed. I think they look much better than the short silver ones.
Then 2 hours of this:
I ended up with this:
Looking at ^ picture, it would have been a smart idea to move the seam of the leather joining to the top of the wheel. Make it like a center point marker thingy.
Pretty happy with the way it turned out. Not bad for a $3.64 investment.
Link of cover below:
http://www.ebay.com.au/itm/171738984046?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Edited by shubby0901
  • Like 1
Take off the whole cowling, plastic piece infront of windscreen under wiper arms, clean off silicon remove old dry rubber piece and respray plastic with proper plastic paint, looks thousand times better just likenew again
Little things like this is why all build threads help the community! It's not always about a million killerwasps!!
Keep up the good work and posts!
PS. i totally ordered one of these :whistling:
Good luck, hopefully yours turns out just as well.
Two things to note:
1) Make sure the thread doesn't get tangled, I had to cut mine in half because it got caught in the seat belt clip thing next to the seat
2) Make the seam so its at the top or bottom of the wheel, I reckon itll look much better.
Small things, one by one making the car just a nicer place to be in (although its already awesome)
The title of the thread is "Living with an R33" so I would like to mention how feel living with this car.
1) Its awesome. The car is so mechanical and pure. You do everything to drive whether its low speed or high speed, everything is just so much fun. I learnt to drive on Corollas and Civics so this is completely different so so much fun.
2) It gets attention whether you like it or not, no matter how stock it is. I've lost the number of times I see people trying to race me at the lights or just looking and admiring (I hope)
3) Its expensive. Fuel is expensive, parts are expensive. It just needs to be taken care of. And if you are like me, you'll spend a lot of money on cleaning supplies....
4) Its not practical. I always say, space is a premium. Glove box is too small. Centre console is too small. boot is too small. Car is massive. Yet I love it.
5) Kind of contradicts previous point, but you can go on surf trips with it ;)
10854489_10202067502124228_1259039919913
Who knew spoilers were so useful! So much extra downforce....
Quick update, I bought myself a very nice expensive camera lens so car mods are on hold for a bit. Next thing is changing the alternator/aircon/power steering belts...one of them screech so it would be safe to assume all of them are aging..now to find somewhere to buy belts...
  • Like 1
  • 3 weeks later...
Work on car has been slow. Exams are coming so I don't have too much time to even drive it..forget working on it.
But to break the chain, today I bought and installed a set of bonnet dampers. They were actually for an R34 but fit on mine perfectly. Apparently the guy had bought them through a group buy on here earlier but never got a chance to install them.
Actually installing them was a piece of cake. In the process of installation, I somehow dropped the 10mm socket behind the headlight...that was fun get out. Only took like an hour and half.
The only issue I got when installing was I installed the bonnet brackets wrong. Pics below. Short explanation, I installed the right and left brackets facing the car. Actually the plates need to be swapped around, therefore right and left facing away from the car. (DUHH) :wacko:
Installation in process. The bonnet opens wayyyy further than the standard amount using the stick thing therefore expandable broomsticks are a must. (Note: Plates are wrong in this picture)
Install should look like this
Not like this
Other component is the fender ball (Note: Plate is wrong in this picture too)
Has anyone replaced their windscreen washer jets with something with a better spray pattern? Im looking for something the same size or bigger so there are no holes around the jets
Finished exams so thought I should have a celebratory car engine bay cleaning session. So I bought a 5L bottle of Degreaser, couple of spray bottles and a paint brush and got to work.
Below are some before and after shots. I started and half an hour later what you see in the after shots is what I ended up with....not much different. So I gave up and am now thinking about what I can remove/move/paint to make it all look cleaner.
Before:
After:
  • 3 weeks later...
What's a fender ball? What does it do?
Thats the ball part of the ball joint for the other side of the hinge. It screws into the fender therefore fender ball.
No updates since I was in Japan for last few weeks, hopefully more updates coming soon.
Latest project i have started is painting all the wheels. As of now, theyve been washed and sanding materials and primers bought. Sanding starts tomorrow. I will post pics as I go along, hopefully they come out decent.
Still havn't decided on a colour though, swaying towards white again.
Fresh silver could look good?
In saying that, a fresh coat of white would look good too!
Not sure about silver, although it would look good, just doesnt do it for me.
Anyway started the process. Progress pics below. Doing it in sets of 2 at the moment as it is limited by space.
Washed up ready for masking
Masked up ready for priming (Sanded the rims after masking but before priming)
Primed up ready for sanding and then re-priming:
(Don't judge my noob painting skills. Also the insides will get primer, at the moment i've only sprayed the outside with primer filler, insides will get etch primer)
Uni starts tomorrow so further progress is time permitting.
Also im digging the primer colour, thinking about painting it so it comes out that colour with a matt finish.
  • 3 weeks later...
So all the wheels are primed up. Got a set of blank center caps which need to be primed and painted. Haven't got a chance to go and get some paint made, thats next on the list.
In the meantime, I got my hands on a GTR type spoiler.
Car went from this
to this
Looks really good. Another thing off the list.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
