Yeah that's fair enough. I like the GTR wing because it looks more 'sporty'. Also its different, which I really like. Its a cool look which I wanted for the car. Now need to get the wheels done asap so I can move on to next bigger and better things.
  • 3 weeks later...
Progress has been slow. Wheels still in the process, considering getting them powder coated as I dont seem to have time to ever paint them.
Ordered some new square plates so they fit better in the number plate slots on the bumper, excited for those.
Also working on a project with my Mechatronics engineer friend....well I can do the mechanical parts, need electrical help. Actual success will posted up here soon hopefully.
  • Like 1
Weather has hampered any progress on the wheels. Uni assignments have stopped all progress on car.
I have however installed new LED revese lights, tried a few different types of bulbs but the results are below. A cheap and easy mod. The new lights are much brighter and look wayyy cooler.
Left is the old bulb, right is the new LED bulb.
Link of ebay ad:
http://www.ebay.com.au/itm/141630746334
Its a good looking wing, looks like a aircraft wing or somthing when you looking back from the drivers seat, thats big improvement on the reverse lights :thumbsup: looks much sharper , i never even seen those lights til now.. :special:
Yeah it looks good. It is somehow the perfect height to block headlights of cars behind me so that I dont get blinded by them.
Reverse lights look good, im interested to see how long they last being cheap ebay bulbs.
Started painting wheels finally. Should be done soon. Also partly installed a dashcam, just need to fix it to the screen.
Also got my Dashcam and installed it. Its the Mini 0805. I will upload a mini review soon. Hid the wires behind the a pillar trim and then behind the driver kickpanel.20150911_111707_zpsmofrjgoy.jpg
Edited by shubby0901
  • Like 1
Finally finished painting the rims. Got the tyres fitted up and wheels installed. I reckon it looks awesome. Ill try and get some photos in the day light and see if I can get the metallic to sparkle.
Hyped to finally get the wheels on....
Time for a photoshoot with the car clean and shiny
Got the rears wrapped in Pirelli P1's, the fronts still have the older Nexen N6000 which I will change when they wear a bit more.
Time to think of the next project now.....
Looking heaps better i reckon, maybe needs work on the stance a little
Could do. I drive the car everyday to uni so I am very keen on making sure it is dailyable. Maybe needs a bit more lowering, king springs?
Yeah that would be cheapest way to do it, i actually got a full set you can have cheap if your interested... they'll make have the arch just over the tyres..
Just the springs cause the shocks are wasted.. post-70965-0-87793300-1443156325_thumb.jpg
Edited by AngryRB
Cheers for the offer but I think my next thing is an exhaust. Im trying to do some research about what to get, intrested in getting a Varex setup but not sure. Is anyone reading this running a varex? I would like to know your setup i.e. cat?, mid muffler?
Did a car service today. Changed oil, spark plugs and filters. I need to change my accessory belts too which I tried but without knowing what to do, was hesitant. Might look for someone who knows what to do and can teach me for next time.
Let me know how you go with the belts. Pretty easy but either the A/C or the P/S (I can't remember which one) is an absolute bitch. You have to get it from the side. I found it easier to unbolt the whole damn tensioner by itself
I ended up giving the belts a go. I was scared at the start cuz I couldnt get the fan off but it wasnt that hard. Ive typed up a DIY tutorial too, will upload it later as I couldnt find one for myself.
No more screeches...YAY!!
The PS one I believe is the one which is from the side. Worst part is I dont have a ratchet spanner so the tensioner took about 20mins to tighten as the spanner would only turn 10 degrees or so everytime.... :glare:
Air-con one was easy since you can get to the tensioner from under the car.
The thread also has over 3000 views...that blows my mind. Thanks alot guys!
alot of people hiding in the shadows... lol... nice one with the belt changes, how do you decide how much is enough tension, thats always been a question in my mind, im sure it says in manual but its bit up to judgement ?
I read a while ago that you should just be able to twist the belt to 90 degrees. If it goes past that, then its too loose and if it doesn't reach that then its too tight. I'm not sure if this is correct but im sure someone will correct me if im wrong. Manual probably has numbers which you can measure using tools designed for it.
I also installed what they call "square" (they're still rectangular) plates here in SA. They look nicer and actually fit in the cut out of the stock bumpers designed for jap plates...looks wayyy better
Quick Review:
Pirelli P1 Tyres
After driving around with these tyres for a while (only on the rear wheels), I am very impressed. They have stupid amounts of grip, espcially compared to the old Nexen N6000 I had before. It is very hard to get these to spin, you have to have really high revs and then drop the clutch. This is in the dry of course. They are pretty quiet too. I have noticed a move in the road noise to the front of the car (older Nexen tyres).
They are reasonably priced too compared to others in the same range.
I am yet to see what the wear is like., will post again later.
Will highly recommend to others.
  • Like 1
So I got my headlights polished. They were really really bad and required some serious work.
I thought about doing it myself but decided it was not worth the risk.
So here are some before and after pics.
After:
Looks heappps better, totally worth it.
I seem to have reached the end of my exterior looks mods/repairs so now onto the performance of the car. About a week from now, it will be 1 year that I have had this car. Time to look for a cool as bday gift?
  • Like 2
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
