I was going to sit and study for exams, but then I thought that's boring so I changed the coil packs. The car is so much smoother, idle's smoother and quieter and revs quicker too. Another thing ticked off the list.
I havnt forgotten about this thread of the car, im now working full time during the week as well as part time on the weekends. I want to work on the car but got no time....hopefully I can put aside some time to keep working on the car.
Also my first DIY got approved so have a look, give me feedback :rolleyes:
Small amounts of time on my hands now. So I decided to add some rice, therefore added some LED lights in the footwells. They turned out pretty well actually. Not sure if a tutorial exists but if someone wants one, ill write one up...well I'll probably write one up anyway.
Edited by shubby0901
  • 3 weeks later...
Thanks guys.
I had plans to get an exhaust made before christmas but the muffler I want was not available anywhere, so now I will probably get it done around the end of January due to work and travel before that.
So over the weekend I attempted to fix the passenger side mirror as it doesnt fold in. After pulling the whole thing apart and thinking the gears are jammed, I pulled them out cleaned them, bought new grease and greased them up and reinstalled them...only to have it still not work... :yucky:. Mirror had to be reinstalled as I need to drive to work tomorrow. On the hunt for a mirror which has a working folding mechanism to swap it out now.
Greased up gears:
In the process of removing the mirror, I smashed the tweeter when I didnt realise it as hanging and closed the door. Luckily it was only the casing so I thought what better excuse to properly mount the tweeters.
Went from this (ignore the missing door card)
24fc5ddf-17f6-4fe7-ab2d-59f8a6c9e719_zps
To this:
6e97d29e-c3ff-4fa1-8190-7d271541c798_zps
I call it a success and it makes the interior look so much nicer.
Hey mate - You will find the issue isn't the gears rather its the contacts in the switching mechanism in the mirror. Happened to me and I used this guide to fix it:
http://www.sau.com.au/forums/topic/93178-r33-electric-side-mirror-repair-s2/
Shortly after I fixed the passenger side, the drivers side went and I haven't been bothered to fix it lol.
GL - Tweeters look nice like that
  • Like 1
Hey,
Yeah I thought this initially but when the switch is pressed the motor make noise and both if the mirror is open or closed, the whole system doesn't work, anyway i ran out of time to try the contacts solution so maybe next time.
  • 1 month later...
Got the car back. Exhaust sounds awesome!!
Specs: Catback Stainless Steel 3.0" with Varex Twin Tip muffler connected straight to battery.
I will record a video and upload it soon.
7c2e8e96-28b7-4adf-bb9d-3c05ea2461d2_zps
  • Like 3
The twin tips look pretty neat on the car. *thumbs up* So simple yet so nice.
Thanks man.
Following your thread too. Love the front bumper, skirts and pods on your car. #Goals haha
  • Like 1
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
