WOOOOOPPP!! 100 posts..yay :woot:
Thanks guys. Yeah when the valve is closed its got this fighter jet kinda sound..weird but cool.
Personally, I'm not a fan of the canon look or sound so it was twin tips from the start. Looks more stock at the same time.
The exhaust sounds really cool when actually driving, will try n get some videos one evening. Keen for the next part for which saving up has started
In the meantime, eyes peeled for smaller additions/improvements..always open to suggestions... :yes:
Cheers guys.
Performance wise, its not really much different, it feels like it revs faster but that may just be the noise making it feel like that.
With the valve closed, boost takes slightly longer to spool but its not really noticeably worse.
Car needs a proper tune to fully utilize the exhaust.
  • 1 month later...
Yeah...seems to attract bad drivers. I would have thought the loud exhaust makes people more aware of me being there...
Got a quote from Spikes Auto today. Should be all fixed soon if everything goes to plan.
Bored at work so thought I might as-well think about what I want to do more..time and money is limited but no harm in having dreams.
Performance:
> Rest of exhaust changed, (Dump, cat etc)
> Nistune + Retune
> R33 GTR Brembo's
> Return flow intercooler....maybe....
Aesthetics:
> Change front bar. I like the Nismo/Jetspeed thing
> Install some form of rear diffuser
>GTR Pods
> Change front seats, either R33 GTR's or some other branded ones
The list goes on and on but these things I want to do atm.
Edited by shubby0901
  • 1 month later...
Not much progress. Was bored today so I thought I'll give something a go. I cut a blocking plate out of a coke can and installed it on the BOV for some sick pigeon noises. Was all right with car in garage and airbox cover off but while driving wasn't very noticeable so I got rid of it and went back to stock.
What pod filters do people recommend?
I have a 3A racing (yes the one from autosalon mag) - seems quieter than my SCA one I had on there before. Had the BOV blocked when I had the SCA BOV and the pigeon were strong with this one
Check out my build thread if you want to see how I made my pod filter legal (enclosure, brackets etc)
Edited by kingtube69
Cool thread, had a quick read, will look up more about these things..
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
