WOOOOOPPP!! 100 posts..yay :woot:
Thanks guys. Yeah when the valve is closed its got this fighter jet kinda sound..weird but cool.
Personally, I'm not a fan of the canon look or sound so it was twin tips from the start. Looks more stock at the same time.
The exhaust sounds really cool when actually driving, will try n get some videos one evening. Keen for the next part for which saving up has started
In the meantime, eyes peeled for smaller additions/improvements..always open to suggestions... :yes:
Cheers guys.
Performance wise, its not really much different, it feels like it revs faster but that may just be the noise making it feel like that.
With the valve closed, boost takes slightly longer to spool but its not really noticeably worse.
Car needs a proper tune to fully utilize the exhaust.
  • 1 month later...
Yeah...seems to attract bad drivers. I would have thought the loud exhaust makes people more aware of me being there...
Got a quote from Spikes Auto today. Should be all fixed soon if everything goes to plan.
Bored at work so thought I might as-well think about what I want to do more..time and money is limited but no harm in having dreams.
Performance:
> Rest of exhaust changed, (Dump, cat etc)
> Nistune + Retune
> R33 GTR Brembo's
> Return flow intercooler....maybe....
Aesthetics:
> Change front bar. I like the Nismo/Jetspeed thing
> Install some form of rear diffuser
>GTR Pods
> Change front seats, either R33 GTR's or some other branded ones
The list goes on and on but these things I want to do atm.
Edited by shubby0901
  • 1 month later...
Not much progress. Was bored today so I thought I'll give something a go. I cut a blocking plate out of a coke can and installed it on the BOV for some sick pigeon noises. Was all right with car in garage and airbox cover off but while driving wasn't very noticeable so I got rid of it and went back to stock.
What pod filters do people recommend?
I have a 3A racing (yes the one from autosalon mag) - seems quieter than my SCA one I had on there before. Had the BOV blocked when I had the SCA BOV and the pigeon were strong with this one
Check out my build thread if you want to see how I made my pod filter legal (enclosure, brackets etc)
Edited by kingtube69
Cool thread, had a quick read, will look up more about these things..
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
