Living With An R33 Gtst
So, Returned to this happening to a parked car...someones backed into it and drove off.
Initial assessment of parts to be replaced:
  • Front Bar
  • Headlight
  • Grill
  • Reo
...yay.....?
Edited by shubby0901
Typos
  • Sad 1
  • 3 months later...
Car is all fixed...well cosmetically. Got the original front lip completely repaired so its in brand new condition! Gotta stay away from the kerbs now.
Headlights are polished but still have marks, one of the lenses is cracked. Have people replaced headlight lenses? Is it easier to replace the full unit?
Also the actual lights arnt working. Hopefully just needs new globes...
  • 2 months later...
Slowly pulling the engine apart to get the fuel rail and injectors out...the car is running very rich so I want to get the injectors cleaned and flow tested...are there any stock bolt on replacements which people use?
This is what the car looks like at the moment...
  • Like 1
  • 1 month later...
Its been too long since I've even looked at my baby...so yesterday I sent 2 full fuel rails with injectorsd for testing and a refurb of the 6 best injectors to make a set of good OEM injectors. They will be good till I get upgraded ones withc a tune...but first, some of the easy but essential things...this is step 1
  • 1 month later...
After a heap of struggle, got the fuel rail and the car back together. Put 150km on it over the next couple of days.
For anyone who has issues with their cars running rich, I would highly recommend this. The smell of fuel (and actual fuel being shot out from the exhaust) has almost disappeared. The car revs much smoother.
A good cheap mod (is it a mod if its OEM part)! Now to think of the next thing.....
Old vs "new" rail...
Its just easier to get the bonnet off completely and work on the car...spacer.png
  • Like 1
  • 1 month later...
Pulled her out of the garage last week, gave her a rinse and drove her abour 150km in one day....so much fun to drive.
Issue's do arise though, by the end of the day while driving home the indicators stopped working. Turning the hazards on still turns ythe indicators on, but using the stalk, nothing works....gotta pull it apart now...initial thoughts of comon problems?
  • 1 month later...
  • 1 month later...
Hey All,
I endedup just getting a stalk from a wrecked R33 and fitted it but same thing, no indicators. Next step is to trace the wiring to see where it has failed. Any ideas about other common failures?
  • 1 month later...
  • 1 month later...
 Fixed up a couple of little niggly issues and installed a bright LED strip in the boot to replace the standard bulb...makes the car look way nicer and way more..european weirdly.
Currently lookong at headunits for the car. Debating between a Chinese branded Andrpid powered unit or a name brand Android Auto unit....
  • Like 2
  • 3 weeks later...
Working from home means small breaks are for working on the car...started to clean the engine bay, actually very surprised with the results!
This is my process:
Bowdens Orange Agent spray
$1 paint brush to scrub
Wet MicroFiber tower to clean up and let it air dry
Working pretty well. This will keep me busy until the parts I have ordered come in
  • Like 1
Working from home is annoying becauseyoure tempted to work on the cat but cant because you need to actually work...anyway snuck this in today. LED lights in the footwells. I did the same thing before aswell but it never worked properly...cheap LED strips also meant the adhesive died after a small amount of time. This time, decent strips with proper 3M Tape...its looking nice
Bits of the dash are out for a new headunit that is on its way but stuck somewhere due to COVID19....grrrr
13 hours ago, Milkmun said:
Good job man, been wanting to do this as well. What did you cut the power source into?
I ran power from the dome lights, down inside the A-Pillar trim and then did the connections in the kick panel. It splits into 2 from there, one to power the driver side and one for the passenger side.
Working on a bigish project on the car right now...but waiting for some parts which have not arrived due to COVID. Who else is affected by this thing?
In the meantime, I bought some Stainless Bolts to try and see what I like the look of and am thinking of slowly replacing the bolts around the car
Thoughts? I am not sure if I like the socket head.. also needs washers...
  • Like 1
Been following the thread and love the car; have recently (Feb) purchased a 96 S2 in same the same colour. I have got the Type-M rear pods and side skirts, but I really want the front lip like yours, is it part of the front bar or a seperate piece? I see fibreglass ones for sale but I'm going to chase down an OEM plastic one. Car is looming great BTW, I'm doing similar stuff to mine i.e stock, OEM mods/replacements with a few subtle upgrades.
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
