5 hours ago, shubby0901 said:
Thoughts? I am not sure if I like the socket head.. also needs washers...
I think with some nice stainless washers it would look pretty good.
Or you could buy one of those "dress up kits" that have titanium style... but I prefer stainless myself.
Some fresh bling would look great i think. I agree with including some washers to hide that scummy ring though.
I'm pretty sure the lip is a separate piece they add to the standard bar. Never actually seen one removed though ?
I bought one of these for my R32:
https://zspecdesign.com/ultimate-dress-up-fastener-kit-for-nissan-skyline-gt-r-gtr-r32-r33-r34/
Chose the "gloss red" washers to match other custom elements of the engine bay. I think it looks pretty sharp without being too bling.
Rob
Currently I am making a list of all the required bolts....good thing I bought a thread gauge instead of assuming threads of bolts.
I think I will just go stainless steel bolts and washer. I dont mind that button head design, its just a matter of which bolts I change and which I leave....I am leaning towards just buying a bulk order of bolts and changing them out as I go around the engine bay and pull/replace parts..
Completed a coolant flush over a couple of days while I waited for parts to come in.
There are currently 2 majorish projects going on with the car, more to come very soon...hopefully....
Updates to the car:
1) Installed a cheap chinese Android Headunit
The system works..ok for the cost. I am still trying to set it up and giving different apps a go, I will check in again once I have it setup well...
This was easy to install. I bought a Nissan to ISO adapter from SuperCheap Auto, cut the ISO plugs off and wired in the headunit plug and voila, it works!
2) Installed big brakes ?
This was a project of mine which I wanted to do since I bought the car...my R33 now has R34-GTR Brembo Calipers, PMU Pads and Disks and GKTech Stainless Steel Braided lines, running Castrol Response DOT4 fluid.
Image may contain: car and outdoor
These were fairly more intrusive, but some tips if someone else is trying it out:
- Go to a proper fastners shop and gets bolts from there that fit, forget the old stuff that came with the calipers
- Get a nice expensive drillbit and some cutting fluid to drill your hubs
- Get an angle grinder or a reciprocating saw, this works just as well
- Make your own bleeder with some hose and a clear bottle, rather than the 1-man bleeders you can buy at auto-parts stores
Apologies for the average pictures, car needs a clean and a photoshoot with the new brakes....
  • Like 1
Question for fellow Skyliners - What are good intake setups that people use? I am looking for a good looking, well built setup which looks almost OEM. I have no intrest in having pods hanging around in the engine bay.  Is just the HKS performance filter a good enough upgrade?
There's some good looking pod shields out now and easy enough to paint/wrap whatever to make it look good. But from memory, your not running big power so the stock box should be up to the task with a god quality panel filter. Depends how much whistle you want ;)
OEM with filter.
11 hours ago, trel said:
Standard airbox with high performance panel filter all the way.
If you're on a stock sized turbo, trying to get a 4" inlet to line up with the stock airbox isn't fun (ask me how I know) haha
Post pics, then, with a small amount of plagiarism, the task isn't as hard.
Just now, mlr said:
That looks neat.
How did it flow?
No idea, decided I didn't like it so changed to a 4" intake before I tuned the car. Ended up with 323kW... then got bored, moved the gate from the housing to the exhaust manifold, made 372kW, then about 5 track days later it went bang lol.
  • Haha 1
  • 3 weeks later...
Some small but highly effective work done on the car today, got some small door dings fixed!
You can see the before and after. If anyone is looking for a paint-less dent repairer, Dentech Paintless Dent Repairer in South Australia is highly recommended!
  • 1 year later...
Its been a long time....since I posted here...not sure if anyone's still reading but hey, why not write what I do.
A new battery is installed, the car has been driven and will be driven for a couple of days....get the joints moving again....
Order some small parts....and let's get this car going again!
  • Like 2
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
