5 hours ago, shubby0901 said:
Thoughts? I am not sure if I like the socket head.. also needs washers...
I think with some nice stainless washers it would look pretty good.
Or you could buy one of those "dress up kits" that have titanium style... but I prefer stainless myself.
Some fresh bling would look great i think. I agree with including some washers to hide that scummy ring though.
I'm pretty sure the lip is a separate piece they add to the standard bar. Never actually seen one removed though ?
I bought one of these for my R32:
https://zspecdesign.com/ultimate-dress-up-fastener-kit-for-nissan-skyline-gt-r-gtr-r32-r33-r34/
Chose the "gloss red" washers to match other custom elements of the engine bay. I think it looks pretty sharp without being too bling.
Rob
Currently I am making a list of all the required bolts....good thing I bought a thread gauge instead of assuming threads of bolts.
I think I will just go stainless steel bolts and washer. I dont mind that button head design, its just a matter of which bolts I change and which I leave....I am leaning towards just buying a bulk order of bolts and changing them out as I go around the engine bay and pull/replace parts..
Completed a coolant flush over a couple of days while I waited for parts to come in.
There are currently 2 majorish projects going on with the car, more to come very soon...hopefully....
Updates to the car:
1) Installed a cheap chinese Android Headunit
The system works..ok for the cost. I am still trying to set it up and giving different apps a go, I will check in again once I have it setup well...
This was easy to install. I bought a Nissan to ISO adapter from SuperCheap Auto, cut the ISO plugs off and wired in the headunit plug and voila, it works!
2) Installed big brakes ?
This was a project of mine which I wanted to do since I bought the car...my R33 now has R34-GTR Brembo Calipers, PMU Pads and Disks and GKTech Stainless Steel Braided lines, running Castrol Response DOT4 fluid.
Image may contain: car and outdoor
These were fairly more intrusive, but some tips if someone else is trying it out:
- Go to a proper fastners shop and gets bolts from there that fit, forget the old stuff that came with the calipers
- Get a nice expensive drillbit and some cutting fluid to drill your hubs
- Get an angle grinder or a reciprocating saw, this works just as well
- Make your own bleeder with some hose and a clear bottle, rather than the 1-man bleeders you can buy at auto-parts stores
Apologies for the average pictures, car needs a clean and a photoshoot with the new brakes....
  • Like 1
Question for fellow Skyliners - What are good intake setups that people use? I am looking for a good looking, well built setup which looks almost OEM. I have no intrest in having pods hanging around in the engine bay.  Is just the HKS performance filter a good enough upgrade?
There's some good looking pod shields out now and easy enough to paint/wrap whatever to make it look good. But from memory, your not running big power so the stock box should be up to the task with a god quality panel filter. Depends how much whistle you want ;)
OEM with filter.
11 hours ago, trel said:
Standard airbox with high performance panel filter all the way.
If you're on a stock sized turbo, trying to get a 4" inlet to line up with the stock airbox isn't fun (ask me how I know) haha
Post pics, then, with a small amount of plagiarism, the task isn't as hard.
Just now, mlr said:
That looks neat.
How did it flow?
No idea, decided I didn't like it so changed to a 4" intake before I tuned the car. Ended up with 323kW... then got bored, moved the gate from the housing to the exhaust manifold, made 372kW, then about 5 track days later it went bang lol.
  • Haha 1
  • 3 weeks later...
Some small but highly effective work done on the car today, got some small door dings fixed!
You can see the before and after. If anyone is looking for a paint-less dent repairer, Dentech Paintless Dent Repairer in South Australia is highly recommended!
  • 1 year later...
Its been a long time....since I posted here...not sure if anyone's still reading but hey, why not write what I do.
A new battery is installed, the car has been driven and will be driven for a couple of days....get the joints moving again....
Order some small parts....and let's get this car going again!
  • Like 2
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
