4 minutes ago, vxsr33 said:
The turbosmart fpr 1200's are around $270 on ebay, on top of the price of the s15 injectors. So wouldnt it just be easier and similiar price to get nismo 550s?
potentially, however I still prefer running aftermarket FPRs to reduce fuel pressure oscillating, unless you're on a r34 which has 2x dampers built in.
Did a 1500km road trip over the last weekend. Car performed flawlessly. The only thing is there was steering vibration which got quite bad while braking. Warped rotors I believe. Will be ordering new rotors/pads next week.
  • 2 months later...
  • 5 weeks later...
So as a quick thing, I installed new rotors and pads to the car. They are RDA slotted and dimpled rotors and Bendix GCT pads. Pretty good, not much noticeable difference when driving. You can hear the slots passing over the pads though as you drive.
Currently chasing a steering wobble issue......not sure what the issue is, going to book the car in for an inspection soon.
Basically, the steering wobbles alot at high speed, it isnt balancing/allignment/warped rotors. It gets noticably worse when braking though...
same discs i chose, though mine were the normal silver not dark. I went with Bendix HD pads. Cant say I ever heard a difference when driving though.
How are all your bushes/rubbers on the steering?
Mine started to develop a wobble under breaking and that was the issue.
oh PS. think i saw you driving down NE road the other week. car looks great =D
The disks only have a coating on them so it gets rubbed off when braking. This is good because it remains coated on the other parts of the disks so they dont rust when washed....:6_smile:
Yeah possibly, I drive around alot in that area haha
7 hours ago, Dose Pipe Sutututu said:
Bendix pads? jesus... they're horrible... every single one
Had bendix pads before, were pretty decent. Had no issues with them. The GCT's are also quiet so im happy.
2 hours ago, Dose Pipe Sutututu said:
Decent? lol.. man they don't stop. I think you need to try brake pads like Intima, Project Mu, Hawk, etc. then you'll understand what I mean.
This is possibly the case haha I've always had bendix pads and they seem fine for normal use. Next time ill try some others out and feel the difference haha
you might get an erection :)
there have been people on this very forum that have used bendix pads then blamed their braking system not being up to the task then shelling out hundreds for larger brakes for street use. Silly!
Keen for this. Next time I'll check it.
Going back to pedders tomorrow for another check. See how many of the issues they told me about earlier have been fixed and how many are left/are new.
Pedders will lie to you so you spend more money.
If you own a Nissan import, mandatory things to change are sub frame bushes, replace castor rods, delete HICAS and if money permits get are real diff :)
  • Like 2
The report actually wasnt bad. They said PWsteering fluid leak which I know about, and rear sway bar links have perished.
They said the vibration is due to a flat spot in the wheels so I need to figure that out. Borrow rims from my mates S13 and test if the vibration is gone.
On 4/21/2017 at 9:44 AM, vxsr33 said:
For the power steering leak check all the hoses aren't lose and tighten them up.
Yeah the leak is from the joint where the hoses meet the reservoir. Need to see if I need to actually replace the hoses and if so how to do it/where to order from etc.
on my mates we just tightened up the clamp and problem solved
Factory hoses are shit and dry up over time. Mine are the same, it's probably worthwhile just changing them anyway :D
Check wheel bearings for excessive play and or wheels for buckles...
My power steer hose weaps, I reckon the factory hose clamps are putting enough tension on the hose. Going to replace with normal worm drive ones when I can be bothered.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
