I was going to sit and study for exams, but then I thought that's boring so I changed the coil packs. The car is so much smoother, idle's smoother and quieter and revs quicker too. Another thing ticked off the list.
I havnt forgotten about this thread of the car, im now working full time during the week as well as part time on the weekends. I want to work on the car but got no time....hopefully I can put aside some time to keep working on the car.
Also my first DIY got approved so have a look, give me feedback :rolleyes:
Small amounts of time on my hands now. So I decided to add some rice, therefore added some LED lights in the footwells. They turned out pretty well actually. Not sure if a tutorial exists but if someone wants one, ill write one up...well I'll probably write one up anyway.
Edited by shubby0901
  • 3 weeks later...
Thanks guys.
I had plans to get an exhaust made before christmas but the muffler I want was not available anywhere, so now I will probably get it done around the end of January due to work and travel before that.
So over the weekend I attempted to fix the passenger side mirror as it doesnt fold in. After pulling the whole thing apart and thinking the gears are jammed, I pulled them out cleaned them, bought new grease and greased them up and reinstalled them...only to have it still not work... :yucky:. Mirror had to be reinstalled as I need to drive to work tomorrow. On the hunt for a mirror which has a working folding mechanism to swap it out now.
Greased up gears:
In the process of removing the mirror, I smashed the tweeter when I didnt realise it as hanging and closed the door. Luckily it was only the casing so I thought what better excuse to properly mount the tweeters.
Went from this (ignore the missing door card)
24fc5ddf-17f6-4fe7-ab2d-59f8a6c9e719_zps
To this:
6e97d29e-c3ff-4fa1-8190-7d271541c798_zps
I call it a success and it makes the interior look so much nicer.
Hey mate - You will find the issue isn't the gears rather its the contacts in the switching mechanism in the mirror. Happened to me and I used this guide to fix it:
http://www.sau.com.au/forums/topic/93178-r33-electric-side-mirror-repair-s2/
Shortly after I fixed the passenger side, the drivers side went and I haven't been bothered to fix it lol.
GL - Tweeters look nice like that
  • Like 1
Hey,
Yeah I thought this initially but when the switch is pressed the motor make noise and both if the mirror is open or closed, the whole system doesn't work, anyway i ran out of time to try the contacts solution so maybe next time.
  • 1 month later...
Got the car back. Exhaust sounds awesome!!
Specs: Catback Stainless Steel 3.0" with Varex Twin Tip muffler connected straight to battery.
I will record a video and upload it soon.
7c2e8e96-28b7-4adf-bb9d-3c05ea2461d2_zps
  • Like 3
The twin tips look pretty neat on the car. *thumbs up* So simple yet so nice.
Thanks man.
Following your thread too. Love the front bumper, skirts and pods on your car. #Goals haha
  • Like 1
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
