Why not just buy a known working engine and save yourself the headache. They're cheap enough.
Look up rods and pistons then add in you may be up for a crank also depending on how bad the damage is. Add on the cost of machining and assembly. For allllll of that you could buy two (possibly more) working stockers.
  • Like 1
solved that misconception then.
its the same as asking how much for a respray.
depends whats broken, what issues arrise when you start, how far do you want or need to go, what parts your using, how much your paying per hour, how long it takes.
Its not hard asking people to help you.
They also don't have to help you.
Take charge of your life and do things for yourself. You will gain knowledge and a fulfilling sense of achievement.
It will set a good example for those around you.
  • Like 3
I didn't actually think it would be this hard just to jump online and ask if anyone had done this before and find out an approximate cost...
My bill was $3000. That included machining and the cost to screw it together.
That DID NOT include oil pump, water pump, set of pistons, head gasket or any of the other parts you may change.
Buying something "cheap" because it's busted only to spend what you saved plus much more doesn't seem a good plan.
  • Like 1
To fully rebuild an engine and make it stronger with forged pistons rods etc.
Got quoted about 10k from race pace - Their quality of work is top notch tho
Its all depends on how much you want to spend.
IMO, Its better to just buy a second hand engine, but I prefer to rebuild it so it lasts and I have no future headaches -
Appears there are so many arrogant pricks on this forum, be alot easier to just answer the kids genuine question
Edited by MariahCarey
  • Like 1
I would have to agree the guy only asked an approx cost. Few ego problems
Good on you piggaz :)
Because we all have different engine builders
I paid 7k for a build that had nothing but issues before it went bang
could easily pay 20k + to get something half decent and that doesnt include things like turbos and manifolds
For a R33 Rb25det, it really needs the pistons and valve springs, its a good idea to have it properly built then saving coins. Mine cost about $5G to rebuild including CP pistons, Supertech valve springs plus other bits and pieces.
Well - I ended up cracking my block.
bending my crank
putting metal through my turbos
blowing up my oil pump
putting metal through oil cooler.
cleaning head
machining head
checking new block
getting new bearings
pistons
rods
head gasket
valve springs retainers and guides
new oil pump etc etc
So its cost over $20k.
So lets say a basic build could be $5k. Full forged build with heaps the goodies and pretty much worst case engine damage.....$20k
