9Well so far guys I've done the chasis work and have all confidence its done right. After all i have another r32 chassis i took all the measurement from. For those of you that dont remember this car got in a very bad accident writing off a toyota camary as well.
After yesterday the car is well on its way back. I have a few concerns. I had an rb20 in it originally wit a rom tune ecu running 550cc injectors and z32 afm it was pretty quick. To change the tune all ill have to do is call the guy that tuned it and he sends a new chip. Obviously i know this isnt the way to tune the car properly, but just a start towards a power fc. Now im planning on installing a rb26 running sigal turbo (halset hx35w). This is really a budget build using all my left over parts i have. As for the actual motor its all stock with refurbished head and everything will be stock other than new acl race bearing, mls gasket set (includes head gasket.) New oem oil, and water pump, block restrictor. Thats about it really. Do you guys think i can wire up my gts4 rb20 ecu to work on the rb26.???? Using the 550 injectors and singal z32 afm. Or should i just go for the power fc. ???
Here are some photos of the car repaired so far.
Edited by MJTru
https://www.sau.com.au/forums/topic/456733-gts4-project-advice-and-results/
Hmm. I needed that. Ok. I was thinking nistune. But may just go with the power fc. I have no experience with nistune. Unless some has a setup i can just buy thats a good price. Thanks for that tho guys sometimes i loss my sense of direction. Ill set it up the car and for now just share a power fc, and just upload a tune for the particular car it's in. Ill share between a r33 gtr and a r32 gts4 (rb26) powered.
Here is the last question thats bugging me with the 550cc injectors with a fresh stock motor. What power levels should i expect. And what boost would be my limit.
Edited by MJTru
How would use the 4wd system. Rb25 neo cant never be a rb26 mate. The rwd will limit it to be just that rwd not 4wd. Thats what i wanted. Plus it was just laying around and ya cant beat free.
Edited by MJTru
RB20 should not run more than 14 psi on stock turbo obviously. With other turbo you can safely run over 20 psi no problems and make power up to about the limit of those injectors (which is about 550 engine HP).
I totally understand that. What would the power potential be for the freshly built stock rb26. Even if i up the injector size. ??
So... you have a RWD GTS4?
Sorry i said that a bit wrong. The gts4 that i have is 4wd. But if i was to run a rb25 wouldn't it turn rwd. ??
Eather way id choose a 26 over any 25
Edited by MJTru
I think the standard answer for such an open ended question is "more than 9000".
Keep in mind that the RB26 was effectively a 400-450HP engine straight from Nissan, without really being pushed. I mean really, you can probably make 700 engine HP on a stock RB26 without risking breaking too much. The numbers are really rubbery though, because it depends on what you mean by "make". If it's an occasional squirt at that power level it is entirely different to getting raped on the dyno or drifting, or heavy Friday night street drags or circuit work. Each of those will place other loads onto the engine (like oiling) that come into play differently.
Hmm. I never thought it was 450. Thats good for me. I know what you mean about how you load the motor. I really dont want much. Just more than 300. Lol. I have owned several rb25s from neo to r33. To me i just like the 26 better. I drag race thats it.
I actually also had a rb25 from a r33 gts4. It must have been because it was stamped rb25 and had the bolt holes for the 4wd oil pan on it like the 26 and 20 from gts4 originally.
There are awd RB25's, in quite a few models.
26 over a 25? That's why the prices of 26 long motors is stupidly high, because fanbois think the 26 is the better engine.
EXACTLY!
If you take a close look at the neo.. Then you know what's what.
Yeah f**k neo's, sell them to me cheap :)
Hi sorry for the delay on this build. Well i just finished the motor build. Was a little hold up on the head drain. So i just built my own. I step back and looked at it and decided to do it a bit different. I drained it into the rear turbo return and im going to vent the bottom end from the front turbo return seeing how thats the highest point. The actuall turbo retun is on the oil pan using dash an10 fitting. All my other setups have the head drian going all the way back to the front. To me that a long trip and the forces of foward movement is trying to keep the oil back even in the pan. More downward trip (hense) should keep things moving. Only drow back is in the oil pan. The rear of it is only so big so at some point it will start flowing foward. I guess. Lol. The oil pan is bigger so the extra oil is also a bonus.
Almost done guys. Quick question.
Would a walbo pump support 500hp at max. Im looking for a fuel pump thats intank but not to expensive.
Was looking at walbo GSS342.
I guess i should ask what does the oem pump support as well:unsure:
Thanks in advance
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
