raced the BMW 320 Turbo today in Project Cars, man such a fun car. crank up the boost to 2.6 bar and let it loose. got the ol' skool no-power-till-6grand kind of turbo.
(turn up the quality)
love a bit of dirty overtaking ;)
They are redesigned and modified specifically to suit a particular Sim and are easily added as long as you understand the directory structure and follow the Info Text file.
I can get on TS if you like to give you a hand with rFactor, GSC, Assetto still learning what makes PC tick .
  • 4 weeks later...
got lucky, bought a new gaming laptop and reloaded PCars only to learn that the savegame does not travel to the steam cloudstore.
luckily for me i removed my old ssd cdrive and could recover the folder. there was no way i was doing the damn 24hour again.
Built with a budget but I suspect you might struggle with higher end Racing simulations such as Assetto Corsa and Project Cars unfortunately.
What Graphics Card ?? I know that there is on board graphics but that is for the Office for good gaming experience you have no choice but to invest in a good PCIe Graphics card.
Some AMD Chips run pretty hot and for the cost of it I'd have gone to something like a Corsair H80 or H100 Liquid Cooling, draw cool Air into the case near the floor and channel this through the case to ventilate it and remove as much heat as possible by air flow, IMHO there is no substitute for Airflow
The HDD you have selected is adequate for your needs but a relatively slow one at that even though it is SATA 3, and your only using one HDD ???
IMHO you should be using no less than 3 HDD's or more for general programs etc and an SSD for the OS .
Basic layout might be something like that listed below
1 OS should be on a 60Gb/120Gb SSD and ONLY the OS
This requires installing the OS and then editing the registry externally in Safe Mode so the default location of your User folder and the default location for your Program Files is on other drive's and NOT C:\ .
2 All other programs are installed something as follows
D;\ For your User Folder and Documents
E;\ For general Programs and Applications
F:\ Being a 500Gb 10,000 rpm Gaming drive so you have some decent speed of I/O .
G:\ Being a 500Gb 10,000 rpm Gaming drive so you have some decent speed of I/O.
H:\ A Caddy for removable Large HDD used for creating Images or Backup's of you installations.
( The reason behind divorcing the OS from everything else is 1 it is faster and 2 it greatly protects your installed programs from loss of data should your OS fail and eventually it will.
So if you back up your C:\ ie your OS regularly to an internal caddy removable backup drive the heart of your system can be protected with minimal loss of Data )
HDD Caddy fitted to the system and you insert a backup drive and image your C:\ and D:\
Storage and backup space is cheap,
What OS ? 32 or 64 Bit you didn't say and IMHO I'd not install Windows 8 for gaming. it is NOT flexible enough to allow custom installations and designed primarily as a Multimedia platform.
Cheers for reply yea was more a budget work computer just wanted to know if it would run games.
Yes the ssd was for OS, no graphics card atm but if the rest isn't good enough I won't even bother and just at a later date upgrade it or build another I guess. But sounds like almost everything must be changed for it
Not necessarily , but that's how I build my systems , and why I separate the OS from everything else and make images of the OS ,
That system would likely run OK for rFactor and Game stock car but I think you would need a high end graphics card for serious gaming simply due to the complexity of the graphics texturing but more so because the computing power is done by a GPU Graphics Processor Unit freeing up a LOT of CPU cycle time to run the mathematical calculations needed.
Suck it and see would be my advice as many games have a trial, to test your machine's capability.
The BAC mono is another fun car to drive, can hold some good power slides.
Edited by HR31_RB20DET
which sim has the biggest list of aussie tracks? Prefer scanned tracks but mods will do also.
It would be hard to beat rfactor for sheer number. If you can get past the ageing graphics its still one of the best sims, especially with the realfeel FFB plugin.
Exactly. I listed 20 aussie tracks off the top of my head - I'm sure there are more that I forgot about. Ageing graphics don't bother me. I can see where I'm going, can use the car's gauges to give me vital info, personally I don't need any more bling than that (and my Dell laptop won't run anything much more graphics intensive than that anyway)
Realfeel is good, but takes a bit of setting up to get it feeling right
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
