The brake pads on my r33 gtst series 2 have been replaced with bendix ultimate pads. They work fine how ever the make a horrible noise when coming to slow stops. I have put anti squeal on the rear of the pads but it done absolutely nothing! The rotors are fine. When I was taking the caliper off the driver side I used a little to much force on the spanner and it bent the brake line inlet into the caliper, surely that wouldn't be the problem would it? Help!!?
https://www.sau.com.au/forums/topic/456749-brand-new-brakes-squealing/
I disagree, they are not crap. I used multiple sets over many years of hard street/light track use. They don't necessarily squeal (of course no manufacturer would knowingly release a product that couldn't be used). They are nasty for dust though....
Squealing happens because of high frequency vibration. You need to make sure all the surfaces are super clean (use brake cleaner generously). Ensure the surface between the hub and disc is free from rust so the disc sits flat. Ensure the caliper mounting to the hub is clean and straight. Make sure you have the anti rattle shims and that they are very clean on both sides too.
And like Ravi said, try bedding them in again. How did you do it the first time? Are the discs new, old but machined or just old?
I didn't research before I bought them, it does seem there are other people having the same problem with them. Apparently they do stop when they get up to temperature but I don't brake hard all the time so they never do. I have cleaned absolutely everything it's driving me insane. I've tried bedding them in multiple times, 60-0; 80-0; 100-0; 120-0. They are on the old unmachined rotors too, although they look and feel fine. It's only the front brakes to might I add.
Please tell me you a) looked up squeely brakes and b) have shims with those pads.
As have been said in every bloody thread regarding brake squeal.
Rub face of brakes
Machine rotors (get new ones if yours are ratty)
Bed them in properly
Do you have shims????!!!!
Oh you do?
Get different brake pads
Still no good?
Do you have the retaining spring on top of the brakes holding the pads down?
Did you check to see if your caliper bolts are tight?
Get them rebuilt
Posting on here was last resort. I've read everything it could possibly be. I never researched the pads before I bought them. I think it's just the pads from what I've read about them. Looks like I'll be buying new ones! But not before doing some research on them haha. Thanks guys!
Scrub the surface again and re-bed them in.
  On 21/05/2015 at 6:13 AM, dori34 said:
what methods would you guys use for bedding in brakes?
go to 80km, hard brake without lock up down to 20km
repeat 6-8 times
let cool overnight?
Not quite. Drive it around getting faster and braking harder until they are nice and warm then do the multiple medium speed to slow speed stops routine above. Then cruise them around to cool off. Then do it again. Then instead of stopping the process dead.....keep driving them around and using them less and less aggressively to allow them to cool off while still in use. Then they are bedded.
On the topic of Ultimate in general - I concur with Duncan. There's nothing inherently wrong with them nor do they just squeal because they're a sqeally pad. I've used them heaps of time on a number of different cars and never had them squeal to an extent that I'd comment on it. Occasional squeal - certainly. No worse than any other pad though.
    • Sell it and buy something newer? 馃槢
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
