adam wicks Posted May 19, 2015 Share Posted May 19, 2015 Nissan skyline door tighten Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/ Share on other sites More sharing options...
niZmO_Man Posted May 19, 2015 Share Posted May 19, 2015 Not sure what's wrong with your door and/or nose, but okay. Try putting tape around the contact patch of the door catch (hey that rhymes). Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/#findComment-7536358 Share on other sites More sharing options...
Jordy32 Posted May 19, 2015 Share Posted May 19, 2015 Nissan skyline door tighten oh yeah man i had the same problem i just wound it up a little and dabbed some grease mate all sweet never had a problem since Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/#findComment-7536407 Share on other sites More sharing options...
adam wicks Posted May 19, 2015 Author Share Posted May 19, 2015 Where did you put it ? Also I'm talking about when you open the door then close it everything inside the door sounds loose and rattly And also when your driving with the windows down the doors rattle and squeak Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/#findComment-7536427 Share on other sites More sharing options...
adam wicks Posted May 19, 2015 Author Share Posted May 19, 2015 Must be the glass is there a way to tighten it ? Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/#findComment-7536462 Share on other sites More sharing options...
niZmO_Man Posted May 19, 2015 Share Posted May 19, 2015 Take the door skin off and have a look. You can put little rubber pad things on surfaces that touch. Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/#findComment-7536491 Share on other sites More sharing options...
adam wicks Posted May 19, 2015 Author Share Posted May 19, 2015 Yea it's the glass rattling around Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/#findComment-7536657 Share on other sites More sharing options...
Sinista32 Posted May 19, 2015 Share Posted May 19, 2015 As NiZmo said take the door card off, look and fix. If you haven't done it before its easy 6 or so Clips around the outside and 2 screws. 1 is under the arm rest Remove and unclip the wiring connection for the window switch panel (pulls up) and remove the screw there. Once the door card is removed and the plastic sheet pulled back you will find 2 nuts at the base of the window. Tighten Felt pads are at the sill level on the door card and on the outside weather sill. Replace (There is one very small screw on the outer sill at the door handle end. Can be slightly hidden by the rubber) Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/#findComment-7536681 Share on other sites More sharing options...
gts25 Posted May 31, 2015 Share Posted May 31, 2015 does anyone know if you can still get a hold of the felt pads new perhaps as aftermarket? i tried through amayama and they seem to be discontinued Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/#findComment-7543045 Share on other sites More sharing options...
junkie Posted May 31, 2015 Share Posted May 31, 2015 Try the sticky felt pads used for furniture legs to protect polished wood floors. Might work, and the glue is pretty strong Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/#findComment-7543209 Share on other sites More sharing options...
gts25 Posted May 31, 2015 Share Posted May 31, 2015 Try the sticky felt pads used for furniture legs to protect polished wood floors. Might work, and the glue is pretty strong great idea ill check it out thanks Link to comment https://www.sau.com.au/forums/topic/456755-nissan-skyline-r32-gtst-93-how-to-tighten-everything-in-the-door-so-when-you-close-it-is-doesnt-make-that-horrible-nose/#findComment-7543252 Share on other sites More sharing options...
