interested to know which R32 and R33 GTR's have the ducts in the front bumper and which don't, often called N1 slots, located at either side of the number plate? as far as i know, it has nothing to do whether it's a v-spec. maybe it's related to what series it is (1,2,3) etc maybe somebody can confirm.
without
with
https://www.sau.com.au/forums/topic/45677-gtr-front-bumper-n1-slots-ducts/
Only Series 3 R33 GTRs (1997-1998) came with them standard.
If you see any other earlier model GTRs have them, it was either a factory option or fitted aftermarket.
No idea about R32s.
I also have a 1994 R32 V-spec II it dosent have the N1 vents and most of the V-spec and V-spec II i have seen do not have them as far as i know they were only an option or fitted as an aftermarket item only the N1 have it as standard. This is also the same as the lip on the boot lid everyone says it was on all 1994 GTRs as far as i know it was also a option part dont know about the N1 though.
regarding boot lid.... read through these threads.. it was a nismo GTR standard.. but many R32 GTR owners in Japan have added them to their cars.. from all i know it wasn't a vspec standard item.... u never know could have been an option on all R32 GTR's when new.
  • 3 weeks later...
Guest Variable
I purchased a set of the fibreglass vents for my 32 GTR from Unique Autosprts.
Does anybody have any experience in retro-fitting these to an existing bumper?
The guy who was installing them for me struck metal about 40mm behind the plastic bumber. I assume this is the bumper reinforcement bar.
Is it safe to cut through this to fit the vents? (ie. will this weaken the structural integrity of the car?)
Any help would be greatly appreciated.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
