Tomorrow is the last day to put your name forward - we need two (2) more people in order to get discounts. If you are interested let me know!
Ok guys we have reached the end date of the group buy. As we only have 3 confirmed interest I dont believe there will be any discounts but I will contact Alpha Omega and see if they are willing to discount anyway. Will keep you posted.
Alpha Omega have offered to extend the group buy until next Tuesday at which time they will review the numbers.
So if anyone else is interested, please speak up by 6PM Tuesday 9th.
  • Like 1
Ok guys, I received no further interest over the weekend so have emailed Alpha Omega to see if they are willing to offer any deal to the 3 confirmed interest.
Will let you know when I hear back.
  • Like 1
Ok guys, I have heard back from Alpha Omega and after receiving a fourth person interested (via PM) they have agreed to offer a discount to these buyers. They are currently setting up the discount coupon for these people and once I have been notified of it I will contact the interested parties via PM with the coupon details.
Awesome stuff Timmy. Thanks.
Will they extend the discount for discs to suit?
I have sent them an email to see if there is any possibility on rotors if also bought at the same time :)
Ok all, for anyone else interested in the discount on the adaptor kit, Alpha Omega has asked me to give out the coupon code!
To receive the discount, all you need to do is use the coupon code 'sau-gb' on the online shopping cart on the Alpha Omega website.
If you use it, give me a heads up and I'll be able to follow up your order for you. The coupon code will only be valid for a limited time as it has been created for this group buy only.
Warning: Coupon is either invalid, expired or reached it's usage limit!
You snooze; you lose
Lol. I will get in touch with then and see if they will fix it up again. Might not be until Monday though.
Cheers. Maybe I snoozed too late..
Alpha Omega have increased the coupon code for a couple of days to allow others to get their purchase made.
Ok guys, there have been four people jump on the group buy and Alpha Omega is leaving the coupon code valid until the 30th as an EOFY discount. The discount will not be offered after this date so if you are interested in getting this kit jump on it whilst you can save yourself some money!
Cheers to everyone that has already jumped on board :)
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
