Neo Noisy Cams
  • 9 years later...
Thread revival, apologies!
I have a similar issue, strange noise that appears shortly after starting the car, fluctuates a bit with RPM... If you bring the revs up the noise sort of follows / trails behind and then settles if that makes sense?
Engine was built years ago with CAMTECH 268 Cams (9mm lift i believe) and the rest of the upgrade kit with the springs and retainers.
Can you upgrade the pulley itself, if the spring is too weak (same as on the VG30 Lumps) or is it pointing towards another issue?
Cheers!
Hi Bud, Yeah that's the next step, going to get these checked. they were set "bang on" when it was built and its always been present. They may well be wrong though!
  • Like 1
1 hour ago, Dose Pipe Sutututu said:
Another thought, are those actually NEO cams made for the NEO head (shim over bucket) and not the non NEO head (hydraulic lifters)?
They were definitely the correct NEO Cams bud :)
5 minutes ago, Dose Pipe Sutututu said:
Time to get measuring (not a fun job)
Yeah going to have a crack at is this week... Great
  • Like 1
 Share
