Hey guys so i recently fitted a bride euro2 seat and a bride rail into the passenger side of my r34 gtt.
The rail that suits a euro2 is a Bride MO type. I have a RO type with the MO conversion plates fitted to make it suit the Euro2 seat shown in the link bellow:
http://www.nengun.com/bride/mo-adapters
The seat position is now at least 2cm higher than the stock seat making it feel like a bus.
Is there any other rails that sit lower, or any other way to position the seat lower?
last resort id go would be fabricators cutting the rail up!!
You literally need every little bit you can to get the seat down low, especially on the passenger side. Any adapter will make you sit on the roof. Only 2 options would be get just the MO type rail (check it out to see what it looks like first too, as it may still sit you kind of high). Or, get one fabbed, which is what I did with my Gias II's, and it now sits lower than standard seats.
i was told the RO and MO are similar in height :(
who fabricated your rail? and how much did u pay if u dont mind me asking? :)
They look like they would yeah. Actually fabbed it myself. So just the cost of some 3 mm flat bar in mild steel.
  On 25/05/2015 at 12:49 AM, dori34 said:
Shoijiki, was that fab from scratch or a modded bride rail to sit lower?
Modified Chinese universal rail. It was to "suit" R34 GT-T, and it did bolt in! However your head would touch the roof essentially! So all the flanges were cut off and the frame trimmed down and re-welded to sit as low as is possible without modifying the floor pan. The passenger side cannot sit as low as the drivers side since the floor has a large bulge in the RH rear area. However it's still much lower than stock with the Gias seats. Also I extended the seat belt bracket on the rail to be 5 cm higher too, as it feels like its too far down on the Bride/Uni Rails.
I can show you some quick snaps of the modded rails if you like.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
