So my r32 gts-t with rb25det got written off last year, got $10k from insurance somehow so I went to the dark side and bought a 2008 BF XR6T for $12.5k, anyway $5k later and it's making this power! This is K.P.Ms "flywheel figure" the real rwkw is about 320rwkw but this shows the curve. 380rwkw is doable on E85 and more boost.
FMIC, 1000cc ID, clutch, fuel pump, 4" dump & cat, custom tune, stock twin 2.25 from cat back, 265x18 rims
It is laggier response wise than the 25det with a 260kw highflow due to the GT35 being pretty big from the factory however full boost and torque at 3k rpm cannot be beat. Sounds awesome and it will make this power on the stock turbo and motor all day long with 200,000 kms on it.
So yeah, if you are thinking about going to the dark side let me tell you it is absolutely worth it for bang for buck! Also having all the creature comforts of a car that is 17 years newer really is nice, electric seats, leather, ABS, airbags, massive interior, cops don't look at it twice either! Around the hills it handles the same as my GTS-T, obviously one the track it isn't going to be as good due to having almost 400kg on the 32.
Edited by Rolls
https://www.sau.com.au/forums/topic/456842-xr6-turbo-love/
"flywheel kilowatts". Why not print it out in HP, then it will seem even bigger. Estimating "flywheel kilowatts" is like measuring your dick at 4" and estimating it up to 6" based on losing a bit between your nuts and your arsehole.
If it was actually on an engine dyno and MEASURED, then that's different.
Having taken the time to bag you though, XR6T is a decent package and easy to make power from given they're only running 4psi standard. I'm glad you're happy with it. But it's a red flag to a bull posting that sort of thing around here :)
  • Like 1
https://www.sau.com.au/forums/topic/456842-xr6-turbo-love/#findComment-7538109
I do like trolling. Forged internals, 4L and GT35 from the factory makes for about the best value motor you can get. It'll pass a roadworthy inspection every time, I also am far less likely to die when I put it into a tree due to the ABS, airbags and much higher safety rating.
https://www.sau.com.au/forums/topic/456842-xr6-turbo-love/#findComment-7538118
ABS wont help you after you have hit a tree
Might help me avoid hitting it though! I tested it out in the wet and it works a treat with the DSC, can stomp on the brakes whilst turning hard and not only will it not lock up, it will still steer fine as well, 4 wheel braking is pretty cool.
https://www.sau.com.au/forums/topic/456842-xr6-turbo-love/#findComment-7538124
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
