Drove an FG XR6 with 450kw at the rears
Scary quick, but lacks build quality. Creaky door trims, paper thin front guards, bootlid rubbing on rear bar, overly high driving position, mudflaps held in place with single screw (loosely), unpainted plastic door mirrors and shiny plastic door frame inserts...
Yes I agree the build quality can be lacking in parts. Thin panels and plastic where it should really be metal, I've found most new cars are similar.
Also agree the commodore interior is shitloads better than the falcon, if I could get the falcon gearbox and engine in a VE commodore I would take it every single time.
Edited by Rolls
Falcon has a lot more then 2 airbags, I had a typhoon that made 395rwkw and it was an animal and made the power so easily (still had the factory turbo)
Unfortunately build quality let it down as it did on the fg xr6t I owned later, that and the price of fuel climbing at the time and it drinking it faster then I could put it in the tank
Have fun replacing Diff bushes constantly (Requires subframe removal)
Have fun replacing Heater mixer shaft when it breaks. hopefully you have the updated stronger one. (Requires Dash out).
Have fun replacing all the engine rubber seals and electrical connectors due too excessive heat. (From memory the thermostat is somewhere near 92 degrees)
Have fun replacing all the front end bushes due to being flogged out.
Making all that power is fun but in the long run the maintenance bill will be higher if you don't work on the car yourself.
I owned at XR6T and while the engine is by far the best part of the whole car, the rest of the car is poorly engineered.
I couldn't believe how bad all the suspension bushes were after such low km's.
I have owned a 180sx, Silvia, Chaser & a stagea. After working on all these cars the significantly older cars are
1. Easier to work on
2. Handle better
And 3. Run cooler.
My 2c. Take it or leave it.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
