It’s time for me to sell my beloved GTR as I’m getting a deposit together for a house. I’ve spent over $25,000 on parts, you’ll be hard pressed to find a cleaner 33 GTR.
Car was tuned by JEM and made 297kw on BP 98.
Price is 28,000 ONO – Sorry not interested in swaps or trades
Car is located in Canberra
I will be putting photos up over the weekend
Any queries you can contact me on 0 Four 23492200
Specs are as follows, chances are that I've missed things:
Engine – Rebuilt November 2012 – Can provide majority of receipts
Engine block was completely machined (decked, acid dipped and welsh plugs were replaced, crank balanced, bores honed, oil galleries drilled out, x-rayed for cracks ect)
New CP forged pistons with 9:1 compression
I-beam Forged Rods
N1 Oil Pump with Reimax billet oil pump gear
Trust Oil Sump Baffle with extended oil pickup
New Alternator
All seals and gaskets were replaced with OEM items, with the exception of a cosmetic metal head gasket.
All new OEM heater hoses – Over $700 worth of hoses
New Clutch Fan
ATI 1000HP Harmonic Balancer
Greedy 19-Row Oil Cooler with Thermostat and Oil filter relocation kit
New oil pressure sender unit
Head has been serviced, with new OEM camshafts installed
Nismo Engine and Gearbox mounts
New Thermostat
Turbo/Exhaust
Garret 2860-7’s with HKS actuators
X-Force Dump Pipes
HKS Front Pipes and CAT
3.5 Inch Custom Exhaust
Driveline
Gearbox was refreshed with new syncros at Award and Diff in Sydney in February 2015 new 4th gear set installed November 2014, serviced with Redline Lightweight Shockproof
Transfer case was inspected by Award and Diff and serviced with new transfer case fluid. ATESSA actuator piston has been modified to allow faster engagement of the front wheels.
V-spec Electronic Diff was serviced with new fluids
Nismo Coppermix Twin-Plate Clutch
Ignition/CPU
Spitfire Coilpacks
New coilpack harness
Apexi Power FC with Hand controller
Greedy Profec B Electronic boost controller with hi/low boost settings
Tarzan G-Box Installed – Replaces stock G-force sensor. (http://www.speedhunters.com/2012/06/the-gt-r-gets-tarzan-ed/)
Viper Alarm system with immobiliser, tilt sensor, glass break sensor and shock sensor
Fuel
Walbro 240 hiflow fuel pump
Flow tested injectors
Suspension/Handling/Braking
Tien Monoflex Coilovers
Nismo ball joints
New tension Rods and Universal links
Cv Joints replaced
Suspension calibrated by Capital Steering and Suspension in Canberra
Michelin Pilot Sport 3 – Installed 10,000kms Ago
Nagisa Auto strut braces – Attach to front quarter panel
New DBA T3 Rotors and Project Mu Pads with DOT 4.1 brake fluid
Interior
Reinforced driver’s seat – Frame was reinforced with thicker cold-rolled steel. In addition the seat and backrest foam was also replaced.
Nismo Centre Gauges
Genuine Nissan Floor mats
Exterior
Series 3 Xenon Headlights
Nismo Clear Front Indicators
Nismo Clear Side Indicators
OEM Series 3 Front Lip with Brake Ducts
Series 3 Bonnet Lip and N1 Vents
Nismo Wing Caps (Carbon)
Nismo Weathershields
Other things
New Battery
Serviced with Motul Fluids ever 5,000kms
I have spare parts including stock edu and Quest LED Tail-lights
Hey mate, did you have the motor built, who was it built by and what boost pressure are you currently running through it ? Also is it still running the standard fuel system i.e injectors, rail, pressure reg etc ? Is it neat in the body, has it ever had a hit, paint etc ?
Bump - For everyone thats been asking, yes, this car will pass rego. New tires, legal height and even legal window tint.
  • 4 weeks later...
Been watching your car Since you advertised it on Carsales.
Hope you got close to what you were after, one damn nice car.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
