Hey all
I have an R32 Gtst and the motor has karked it.
so what i want to do it get it rebuilt, with some forgies, better valves/springs, GTR cams etc.
Where in Vic could i get this done? or at least get the parts from?
I think i can get most of the work done but just dont know where to get the parts?
i can do the bottom end, but i guess i will need to get my head reco'd somewhere?
anyone had any good experiences with anywhere in melb?
If so where abouts? what did you get done? and how much?
i have about 5 grand to get it all done but i want to budget in there some aftermarket management, so i guess around 3 and a half grand for the lot.
Any suggestions. thanks all, much appreciated
https://www.sau.com.au/forums/topic/45686-where-to-get-rb20-aftermarket-parts/
Dont they do a lot of work with RB26s... RB20, 25, 26 same thing? Did you speak to them?
i just spoke to him through email, he said they dont do work on RB20's and that i should talk to some Dean bloke from Ultimate Performance or something but i think that was concerning the RB25 conversion which i dont really want to do anymore... i just want to get my RB20 rebuilt with stronger internals etc.
Anyone got any other places that they know work on RB20's?
Thanks all
inark: i only the car for around 2 months or so but i think some of the reason for its death was due to over boosting as i ran around 14 - 15 on it sometimes when i got my new controller... though when it actually died it had been on 10 - 11 all night which is as low as i could get it to go on my controller. as in whyen it is set to 0 extra boost it still goes up to around 11 which i heard was normal for a stock turbo with aftermarket exhaust / pod filter so i didnt really worry about that..
oh well. seems i may come out of it with something a little better anyhow..
Cheers all
ouch... i was running mine on 14 to 15psi for 14 months and then just left it on 12psi or the last 3 months and never had any issues... i know the guy i sold mine to about 2 months ago hasnt had any issues with it either and hes running 13psi through it.
id say there was something grossely wrong with it to begin with.
yeah maybe. mine would often gp to around 17PSI sometimes though...
either way. its happened now and im over why it happened and more into what i can do to fix my car.
im thinking of doing the RB25 conversion and keeping the RB20 timing case and making it look like a normal RB20.
Where in melb can i get an R33 halfcut? or working RB25?
oooooo get this SR20DEt and drop that in... much better and cheaper idea :cheers: lots of room in the engine bay for a VMount Intercooler :)http://www.upimports.com.au/UPI_Parts/engine.php
For your money you would be better off Replacing the rb20 with a low km rb20 as and rebuild for under 5k - the managment is gonig to be a half ass job.
Depending on how much power you want i would spend the money on a fresh rb20, managment and intercooler maybe bigger turbo etc because if you don't want more than 180 - 200 rwkw relilably then you don't need forgies etc.
Possibly a wolf 3d microtech or a power fc and don't forget you will need a fuel pump if you want to run decent amount of boost.
OR
Do an rb25det conversion with standard etc
still say my idea of the SR20DET would be a better option... look at meggalas one.. that thing was mean and way cheaper than an RB25DET conversion plus u could have change for mods :cheers:
plus... its different.
Have you seen the prices of SR20's atm its ridiclous rb25's are cheaper atm and not custom work needed.
thats just my opinion
Memph Check your private messages i gave you some info on local people who can help you out
cheers
Id be tempted to throw a std RB20 back in, tow car to mechanics and $2500 later your car will be back on the road with a 3 month engine warranty.
Keep the rest if the 5K in your pocket, as ppl are starting to convince me that the std RB20 is good for 250rwkws, any higher power and the things start to get too laggy, built internals or not. So 250rwkw out of std RB20, or pistons and rebuild and have the strength to run bigger power but wont make the power at a very sane rpm
..... and please dont attempt to put an SR20 in your car UNLESS you have a workshop that will do a lot of stuffing around for free (unlikely) or you have the ability to do 80% of the work yourself, as i dont buy this its cheaper then RB20 theory
yeah good point... im sure meggala would be able to answer that as he got ICE to do his... he may have got a good rate on it... i do know he didnt do 80% of the work.
the upside to using an SR20 is it gives the car a better weight distribution... is lighter... u only have to pay for 4 injectors, 4 pistons etc etc if you wanna upgrade and parts are more readily available and cheaper than they are for the RB20
Amberley Auto
9793 1616
12-14 Amberley Crescent Dandenong
My RB25 is getting rebuilt with forged pistons and the such at the moment
Racepace wont build u an engine unless your planning on spending $10k+
Theyll just forward u to UPI
Also, budget more than $5k cos ull be spending close to $2k on labour alone...if u want a job well done
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
