What's the purpose of the equal length? The last few I made have been twin 3 into 4 inch stainless, but there is hardly any room left to muck around with equal length pipes... It will just mean more bends and more restriction.
The idea is to get the gasses out as fast as possible, with the least restriction through the straightest and largest pipes that fit.
Isn't equal length meant to help make exhaust gasses exit smoother rather than colliding at the Y piece?
Also, it's for that Mines sound :-)
My Fujitsubo equal length front pipe sounds amazing, and helped with response down low, but has the worst ground clearance....
  • Like 1
yep better merge/flow and sound
The only thing they do is change the sound,
what happens after the turbo doesn't matter, just make it as big as possible to get the gas out a easily as possible
yes but if there is a Y section in your system which merges why would you want any exhaust gases to clash at any time in that merge?
wouldn't you separate them if you had the choice?
Exhaust gases come out of the exhaust in pulses.
