jeez. Just kiss already.
Doesnt matter which way you put it, a equal length front pipe is the best sounding RB26. But if you go single then it sounds mental on its own.
Some say a equal length is beneficial to allow the gasses to flow evenly out to the tailpipe and inturn helps with shuffling. I can definitely say that a equal length front pipe helps with shuffling. My midori front pipe shuffled like a fair bit up inclines. But with the mines front pipe I do not experience the same level of shuffling.
But biggest point here is sound.
The end.
That is not the purpose of this topic and if you go and google I am sure you will find many more theories on the differences.
They hug the body VERY well. I've never bumped them on the ground. They generally won't do an exhaust unless they have THE car they're going on... So they can get the fit spot on. Not sure if that's changed but that was the story a few years ago.
  • Like 1
thanks Piggaz they said they could send me one I just wanted to see if anyone in sydney could make one just as good if not better so I can make sure it fits snug
The unequal length twin 3 inch system on the 33 gtr I have here sounds awesome, if only the 3L bottom end didn't make it sound like a VL.
You seriously think a few extra inches in a front pipe will make it sound any different?
Yes,
http://youtu.be/6dSrNZK6ogc
  • Like 1
for an extra couple of bucks, can't hurt?
You made them?
  • Like 1
Yes,
Lol, you believe a youtube sound clip? That is obviously not just swapping the front pipes. It's the mufflers that change the note, not the pipes.
I agree, it makes little difference to the price, although there are many more bends and you will be sacrificing flow for this equal length nonsense. I like to tuck my systems up, not have them hanging down lower. Each to their own I guess.
You made them?
This was Daz's car, he already had a twin 3 inch system, I am just making it work with the taller block.
I have done a few twin 3 into 4 inch systems, usually tapering back to 3.5 at the mid muffler.
My car came with the usual unequal length front pipe. I changed it to an equal length one (no other changes to the car) and the sound changed (used to sound like my old neighbour's 6cyl BMW, now sounds like a "real GT-R" :P).
  • Like 1
If some of you gtr owners are that purist, perhaps the stock exhaust is the go? I am sure Nissan will still have a few in storage.
The unequal length sidepipes on the Gibson GTR I worked on had a beautiful note at 8000 revs. :P
  • Like 1
Fact is, unequal vs. equal length front pipes produce different sound. I know I heard it on my car. Doesn't mean it sounds any less meaner, just different.
Here's another youtube vid.
Performance wise? probably no difference. Practical wise, unequal is better, my equal length hangs pretty low (lowest part of the car) and has copped some dents.
I am terribly sorry that I used evidence to give you an example. Or maybe the fact that I also changed front pipes to equal length ones and the note changed of the exhaust. Oh and didn't touch the timing nor manifolds. Now you are calling me simple minded? Give me some credit at least.
But I don't know why we are arguing. You are clearly wrong and now it seems you are just hell bent on being right.
That is not the topic of discussion here.
  • Like 1
    • This sounds like a perfect excuse to install a Haltech R3.
    • I do believe from context he is talking about a S0/S1 R33 RB25 with associated ECU and Wiring for that, and a manual gearbox into a R34 N/A Auto. I don't have the knowledge of all the pinouts and such but my gut feeling from doing my own conversion is to use as much of the R33 stuff that you can. The "car" wiring is quite seperate from the "Engine" wiring when all things are considered. The only things to truly consider 99% of the time is the cluster, reverse lights and potentially disabling the 'not in P/N' immobilizer circuit.
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
