my 2cents:
I think you've tried making one in the past and you probably stuffed it up or found it to be quite difficult so you decided to convince yourself and your customer that it does nothing and is a waste of time.
don't be offended a lot people take this approach.
when clearly people are changing nothing other than a front pipe and reporting first hand that IT MAKES A DIFFERENCE IN SOUND AND..."some" also report slight power gains.
MINES have also been known to make pretty good cars and they clearly state that they are only interested in modifications that make a DIFFERENCE IN PERFORMANCE.
My 2c
By the same logic applied above, people who have shelled out $000's on front pipes or equal length pipes will "convince" themselves there is a positive difference in order to justify the spend and maintain the shoppers high they so desperately need.
Just. Do. It.
  • Like 3
My 2c
Just. Do. It.
this, all of this!! And don't forget mines will tell you they are better cause they salesmen and they want you to buy their product.
Power gain is probably going to a bigger front pipe, or something else.
I paid $250 for my front pipe (off fatz), money well spent :P.
Scotty, I think you mixed up something from that video, the first two 'runs' were inside the car, the other two were outside/sound sourced elsewhere (so went HKS inside -> MINE'S inside -> HKS outside -> MINE'S outside). The sound difference (in that video) between the HKS and MINE'S front pipes is pretty small IMO. MINE's one gives a bit more 'bark'.
If anyone has a twin 3 inch with no merge at all would love to hear that sample just to compare them
fatz had that HKS twin exhaust on his car, there might be some videos floating around somewhere.
Mines achieved something, they achieved the placebo effect, just watch their r34 "response monster" video it's a laggy dog with really really short diff gears in it
But
but
standard bore increases response
:unsure:
A laggy dog that can lap Tsukuba in 57s in a full weight R34 GTR...
No one said it wasn't fast, but it's not responsive
Oh and it was an n1 so not quite a full weight r34 Gtr
Have you driven it to call it laggy? Have you seen its dyno sheet? Or are you basing this off of the videos you have seen...
Yes I agree that the reason why it appears to be so quick is because of its short diff gear ratios, however calling it a laggy dog is an over exaggeration... At the end of the day, it is a well set-up car and hence why it is fast
And n1 gtr's weigh about the same as a standard gtr: http://www.jlimports.com.au/nissan-skyline-r34-gt-r-1
So yes, it is a full weight r34 gtr
You can see when it falls off boost they wait, wait and go,
I understand that its a hero car to so many people (it was to me for a while) but sometimes you need to step back and see things for what they really are. It's a set of 2530s on a 2.6 Gtr there is enough evidence around to show how they respond
And it didn't do a 57 are Tsukuba just because of a couple of diff gears and some turbos, it has some serious suspension and brakes sitting under it as well
Im not defending it because it is a hero car, I was more so having a dig at that "laggy dog" comment and how you can make such a statement from only watching the car in videos, and despite the fact that professional racers who have actually driven the car have praised it on its acceleration.
And yes I agree that there is much more to the car than just the engine set-up that makes it fast - and no not the front pipes
thanks Piggaz iv got a tomei stroker too so should be the best comparison yet.
On the dyno. It's the best video I have sorry :/
th_36C2F2CF-1BF4-46B5-B37C-EB14ECBFD4CE-
Although it doesn't show the front pipes, i can assure you the rear pipe wraps around the front.
EDIT: Video's on photobucket suck wang.
  • Like 2
haha unigroup hey, local boy unigroup is where I'm going to take mine for a tune also couldn't really hear the audio too well but it does sound like your engine has shitloads of torque down low which is good is yours on e85 Edited by mr skidz
Taken to PM. Save clogging up the thread with off topic dribble.
  • Like 1
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
