Just to shove a spanner in the works, I measured a set of HKS equal length pipes and found... They weren't equal anyway, there was 5 inches extra on the front turbo pipe.
Anyone have any other brands laying about to check?
  • Like 1
I just assumed it was HKS due to the catback being HKS. There are no markings.
Ah yep. Looks like a hks sort of design. But just like midori or the "new" apexi designs the are not equal length.
Those reimax are pretty elaborate. I'll get a pick of the racepace ones. They look the best.
That looks like a Trust front pipe.
Here are two vids that demonstration of the difference in sound that the Mines front pipe makes.
That is the only difference between the two vids
apart from being inside, and from a different distance and angle...
Curves apear alot tighter than the jap brands, which as scotty has been saying, will restrict flow.
It may be tighter, but most jap pipes are peanut sizes. I don't think I've ever see a twin 3 inch into a single 4 inch off the shelf from ping pong land.
If you want to talk about a 3 inch "tight" bend restricting the exhsust, have a good look at the 2 inch turbo inlet pipes that bolt to the comp housing. At the smallest point they're about 1.7 inches (It can be fixed by welding it up and grinding the inside out). What about the tight bend in the dump pipes? Bigger fish to fry than a huge set of front pipes.
  • Like 1
^^^ Hahaha. So good!
Anywho. If we all wanted power and cared so much about restriction the we would bolt on a single have a 5" dump straight out the bonnet.
And I really find the jap pipes to not care about ground clearance. They just hang there like dingle berries.
  • 3 months later...
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
