Hey guys & gals, this is my first post :cheers:
A little bit about myself before I get started. I'm 16, soon to be 17 and provisionally licensed. Looking at a R32 GTS-T as a first car. I've been surrounded by cars since I was born (Grandparents into rodding) so I do know how cars work, how engines work, suspension, brakes, upgrades etc.
However, I saw these images on a previous thread and they caught my attention. Due to the amount of controversy about RB20 intake manifolds and low torque due to shorter runners etc, these images really had me interested. If anyone could shed some light on the process of doing this, how hard, what is needed, if it's even worth it? That would be very very much appreciated.
Cut up manifold.
Make parts to put throttle where you want it. Out of Aluminum.
Get weldded together.
Bolt onto engine.
Why. That's the question.
Mainly to reduce IC piping, cleaner engine bay, easier access to ignition, all whilst retaining the stock runners and plenum without suffering torque loss in the low end. Also, for that factory look. :P
Do you have a link to the thread for the first picture?
I'll swing you the link when I finish work man :)
  • 4 weeks later...
The one thing to consider with this is that you are taking an inlet manifold that is designed (by people who know a thing or 2 about airflow) to flow in the stock design and then pumping air in from a totally different direction. It might look tidier, and improve response by 0.0001 of a second because of there being a little bit less piping, but at what cost? You'll probably find that number 5 and 6 cylinders lean right out, while 1 and 2 run rich. And the best bit is that unless you hook up a wideband o2 sensor to each individual cylinder, you don't have any idea that it's happening until your engine pops.
And being around cars all your life doesn't mean you actually know how stuff works. What it means is that you may know a lot of information, but it doesn't mean that the information is correct.
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
