Hey guys & gals, this is my first post :cheers:
A little bit about myself before I get started. I'm 16, soon to be 17 and provisionally licensed. Looking at a R32 GTS-T as a first car. I've been surrounded by cars since I was born (Grandparents into rodding) so I do know how cars work, how engines work, suspension, brakes, upgrades etc.
However, I saw these images on a previous thread and they caught my attention. Due to the amount of controversy about RB20 intake manifolds and low torque due to shorter runners etc, these images really had me interested. If anyone could shed some light on the process of doing this, how hard, what is needed, if it's even worth it? That would be very very much appreciated.
Cut up manifold.
Make parts to put throttle where you want it. Out of Aluminum.
Get weldded together.
Bolt onto engine.
Why. That's the question.
Mainly to reduce IC piping, cleaner engine bay, easier access to ignition, all whilst retaining the stock runners and plenum without suffering torque loss in the low end. Also, for that factory look. :P
Do you have a link to the thread for the first picture?
I'll swing you the link when I finish work man :)
  • 4 weeks later...
The one thing to consider with this is that you are taking an inlet manifold that is designed (by people who know a thing or 2 about airflow) to flow in the stock design and then pumping air in from a totally different direction. It might look tidier, and improve response by 0.0001 of a second because of there being a little bit less piping, but at what cost? You'll probably find that number 5 and 6 cylinders lean right out, while 1 and 2 run rich. And the best bit is that unless you hook up a wideband o2 sensor to each individual cylinder, you don't have any idea that it's happening until your engine pops.
And being around cars all your life doesn't mean you actually know how stuff works. What it means is that you may know a lot of information, but it doesn't mean that the information is correct.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
