2001 Toyota Hilux 3.0L Turbo Diesel SR5
Swap for Stagea M35 AR-X and cash my way, feel free to make me an offer
http://www.carsales.com.au/private/details/_/SSE-AD-3296656
Great work ute or weekend tourer. Very uneque with rare features. I got this Hilux about 2 and a half years ago for a work ute and a tow vehicle and has not missed a beat. It has been serviced by the book up to 200,000km and every 5,000km after, just did the timing belt 5000kms ago. There are a few small marks on the body but it has been used for what it was built for. The motor is solid and hasn't been touched, it is great and smooth to drive. Selling it as we have just had our first child and no longer require the ute for work.
-RWC & Rego until September 2015
-262XXXkms
-Aluminum Bull Bar
-Factory Safety Pack (Dual airbag & ABS)
-Power windows & Mirrors
-Factory Black Leather look seats
-Manual
-LSD (New Reconditioned rear diff and diff bearings from ARB on 11th June 2014, have receipts)
-Exceedy Standard Replacement clutch
on 13 August 2013, have receipts
-Cooper STT 31x10.5 mud tyres on 3rd October 2014 (have receipts
-15 inch Sunraysia steel rims painted black
-Genuine Toyota Side Steps
-Safari Snorkel
-2 inch suspension lift
-Dual batteries (Main optima deep cycle yellow top, aux in tray with 1000w 240v power inverter)
-Side steps
-Tow bar
-New front ball joints, idler arms, pitman arms, steering dampers, and CV shafts on 19th June 2014 (have receipts)
-2 full extend 1200mm drawers rated at 227kg.
-1000w (2000w peak) 240v power inverter
$15,400 neg 0478 816 818
Wangaratta, happy to travel
11203648_10152747403487676_6646715506434
11270514_10152747403427676_4343361910388
11008469_10152747403557676_9131737793994
11011990_10152747403622676_8267235839902
11143148_10152747403432676_6189391818402
11289532_10152747403412676_5331397008340
11212593_10152747403337676_7596333827139
11254428_10152747403232676_3576872267752
11134101_10152747403522676_8950190969949
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
