Hi do anyone could find out in which area Top fuel are because my computer can`t
or won`t translate the exact words.I have even tried setting the browser to japanse.Would it be long from Ikebukuro/Tokyo?Maybe Abflug or Veilside also
http://www.topfuel.info/about_topfuel/index.html
http://www.ab-flug.co.jp/
http://www.veilsidejpn.com/
Could i also throw in Knight Sports
http://www.knightsports.co.jp/corp_info/map.html
Thanks
https://www.sau.com.au/forums/topic/45696-could-someone-translate-in-a-hurry/
Top Fuel is in mie ken - that's a long way from tokyo!
Abflug is in shizuoka ken - a couple of prefectures away from tokyo - not exactly close
Veilside - couldn't find their address on the site (must be there somewhere...)
knightsports - is in tokyo, on jounanjima (jounan island) - as far as I can tell, it's somewhere near haneda airport - so there will be a rail line that way (not sure how far), probably need a taxi too
None of them are near Ikebukuro.
Having the addresses in english will mean you are able to pronounce them, but it would be far better to print out the japanese text/maps instead
Thanks DaiOni and 51LBA.
PS would that say that
Veilside's show room is at 1250-3 mase, tsukuba city, ibaragi ken. Less than a couple of hours by train from tokyo i guess.
is near Tsukuba Circuit?
The best thing would probaly be to pick up Option magazine when I arrive in Tokyo for directions like mentioned before on the forum
Thanks
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
