This has been my NisTune/Consult/FAST machine for a couple of years it has worked reliably in that time. Its the perfect size for getting in and of of the car etc (2.2 Kg), coming with a cigarette lighter power supply means you never have to worry about battery. It uses a serial port PLMS (excellent quality) Consult cable.
Dell Latitude D400
2GHz CPU / 1GB SDRAM
80GB HDD
12.1" LCD / WiFi (G)
Windows XP PRO SP3 License on underside
For full specs: http://www.dell.com/downloads/us/pro.../d400_spec.pdf
PLMS Serial Consult Cable
12V Cigarette power supply (90W unit costing about $70)
2 x Dell 240V power supplies
Docking Station, see below for ports.
External DVD drive, plugs into laptop or docking station.
Installed Software:
Windows XP Professional SP3 (COA on base, Genuine Dell installation media included)
Nissan FAST Spare Parts catalogue
Conzult Free
Conzult Manual, excellent for gaining understanding on how to use consult type software.
Nistune Demo (4 starts remaining)
Nissan DataScan 1.6 Demo (Limited functionality)
Nissan Z32 Factory Workshop Manual in PDF
Small side cover missing, picture below, never bothered me.
Battery only good for about 10 minutes. (Cigarette Power Supply Included)
Case finish is coming of in a few places, OK for workshop not boardroom.
Front right click button not working, I just use the one forward of the track pad.
All pretty minor and have little effect for intended use.
Complete fresh software install, runs very well, 30 seconds to desktop, 50 odd seconds to browser.
$245 + Postage
PM me your postcode for postage quote.
Edited by BrisZ
https://www.sau.com.au/forums/topic/456973-consult-cable-laptop-computer-obd/
Hey mate where are you located?
Any idea if consult can diagnose and/or clear a flashing airbag light?
(Had wheel changed stock for stock with original module, been flashing ever since)
Car is running a Haltech ECU but hoping consult could still read the separate SRS system...
I use it for Nissan Z32 300ZX Twin Turbo but it should work for a R33 GT-R, see the list below other Nissans of similar period should also work if they have the Consult plug as above.
Not sure if it will see the air bag ECU with the Haltech in place but there is only one way to find out, I'm Brisbane southside.
  • AUS 200SX S14 (SR20DET)
  • AUS 200SX S15 (SR20DET)
  • AUS Maxima A32 (VQ30DE)
  • AUS Pulsar N14 (GA16DE)
  • AUS Pulsar N14 (SR20DE)
  • AUS Pulsar N15 (GA16DE)
  • AUS NX/NXR Coupe (SR20DE)
  • JDM 180SX S13 (SR20DET)
  • JDM Silvia S14 (SR20DE)
  • JDM Silvia S15 (SR20DET)
  • JDM Pulsar GTi (SR18DE)
  • JDM Pulsar GTiR (SR20DET)
  • JDM Bluebird U14 (SR18DE)
  • JDM Bluebird U15 (SR20DET)
  • JDM Skyline R32 (RB20DET)
  • JDM Skyline R32 GTR (RB26DETT)
  • JDM Skyline R33 (RB25DET)
  • JDM Skyline R33 (RB20DE)
  • JDM Skyline R33 GTR (RB26DETT)
  • JDM Skyline R34 (RB25DET NEO)
  • JDM Avenir PWN10 (SR20DE)
  • JDM Infiniti Q45
  • 3 months later...
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
