Hi everybody
Looking to upgrade the inlet manifold on my rb30dett and just wanting to know if there's any options beyond hypertune out there that might fit my requirements. Specifically:
1) I definitely will be retaining the 6 x ITBs.
2) I want to run a 100mm/4" inlet diameter, in anticipation of going to a full 4" intercooler and turbo outlet system once I convert to a single turbo.
The last time I looked into this hypertune seemed to be the only item that could meet these requirements but I thought that since then something else might have entered the market. I basically want a nice big plenum with a quality, machined face to bolt on, seals properly, that flows nicely and distributes flow to the rear cylinder. The hypertune price range would be the upper end of what I'm hoping to pay and if anyone can recommend a good Australian distributor that I can chat to that would be great.
Also, are there any issues I might have particularly with a deck height that is now +38mm, eg: clearance with clutch mcs etc - I'm already assuming I may need to go to an r33 style clutch mc. I am currently running the factory fuel rail with 1000cc injectors but all the ones I've seen have factory mounts for the rail as well. But any other tips on clearances and fitment etc would be greatly appreciated. Thanks in advance.
  On 27/05/2015 at 2:50 AM, scotty nm35 said:
4 inch intercooler pipes? Man... What's wrong with the 80mm?
Am currently running 22-23psi on a set of HKS 2530s. It has a built rb30 bottom end and big cams, so when I go to a single turbo (around t88 size or so) I will be upping the boost considerably.
EDIT: this is not intended to be a street/daily driver car.
Edited by dorifticon
  On 27/05/2015 at 5:02 AM, jangles said:
Or modify the stock plenum, don't quote me, but RACEPACE did/do that?
I believe it was lengthening the runners for more midrange twist.... IIRC.
  • Like 1
Also, at what power level do ITB's become a hinderance over single?
CPC, custom plenum creations do plenums. So do RIPS in NZ. Both would make what you want.
The ITB's will always disturb the airflow and create a pressure drop across the port compared to a single TB manifold.
If you just want to make big power and less pressure drop through the system putting a single TB on the stock plenum is the cheapest way out.
If you are serious, a much larger volume plenum (which helps with distribution of flow) with a 100mm TB like you want is probably better and big piping, no flow restriction!
  • Like 1
  On 27/05/2015 at 3:15 AM, scotty nm35 said:
The more boost you run the smaller the piping needs to be. Unless you are chasing over 600kw I would leave the stock piping in place.
Currently on 385kw or so (at the treads) but turbos are way undersized for my application. Would ultimately like to get into the 600's once fuel system (including switch to ethanol) is sorted.
I don't want to lose the off-throttle response or the effect of the brake booster on sudden switch from throttle to brake. It's one of the things I like most about the rb. I realise it makes tuning a PITA and may limit power, but have driven a single throttle and it's not for me.
Thanks for all the names/etc so far, will continue the research.
That quote about smaller piping wasn't right, I am not sure what Scotty meant?
In any case, you can upgrade the piping but the biggest restriction will probably be the ITB's, in which case, the money spent upgrading pipe work is best done elsewhere. Unless you do change it anyway to go to a big single turbo then by all means upgrade to larger piping, but you will most likely on get a small gain in flow (less pressure drop) through piping.
Have seen 500kw through the stock piping, now he is going for 600kw. I will let you know how he goes.
After seeing 350kw through 2.25 inch piping, 80mm should therefore easily flow 600 by my books. Just letting you know as most workshops would have upgraded it at much less power. The more you compress the air the smaller the pipes need to be, that much is obvious yeh?
perhaps the word boost should be replaced with air volume in this topic? since there are so many things changing in this setup (turbo, intake manifold, intake piping, power output) throwing around estimations and requirements for boost levels is pretty irrelevant.
no one is doubting 2.25 inch piping wont flow big numbers, i think the question should be 'is 4" piping worth it?' smaller piping flows less (or requires more boost) and dissipates less heat. probably not worth the effort to fit 4" though especially if it limits your plenum choices.
  On 29/05/2015 at 12:44 AM, r32-25t said:
If the turbo outlet is only 2.5in why would the rest of it need to be 4in?
The turbo outlet is only 2.5" because the size of the compressor housing is such (diameter, thickness) that you couldn't easily make the outlet bigger. On top of that, centrifugal compressors basically work by turning air velocity into static pressure. The velocity in the compressor housing is very high, and you want that to slow down as gradually as possible (hence the shape of the volute of the housing). If you tried to take that same compressor housing out to, say, a 3" outlet, then you'd either have to be less gradual or make it a lot bigger (longer in the outlet). This would make for poor performance on the one hand and poor packaging on the other. I think we should ignore for the moment the fact that most such turbos then get installed with a nasty elbow directly off the outlet.
But the velocity in the 2.5" outlet is probably too high for good pressure drop characteristics if you were to keep the pipework at 2.5", so it make sense to go up to 3" or whatever is needed to get the air velocity back into a more reasonable range. And of course people will argue about what a sensible velocity range is and they will argue about what power level = what boost = what airflow without paying any attention to the type or size of engine or turbo. But we'd best ignore that too!
  • Like 1
the piping setup in my 'R needs to be changed anyway, when I got the extra 38mm deck height from the rb30, I did a "temporary" hack and clamp job to extend the OEM rubber pipes and was never super happy with it. So this incremental cost of upgrading the piping (especially in light of everything else) should be not much. There's going to be a lot of pipe cutting and welding in any case for the single turbine setup.
In terms of whether it will be better or worse than the 80mm setup, I figure the stock power on a GTR was in the 200's, so upgrading the cross-sectional flow area by around 60% shouldn't be a bad thing if chasing power levels that are well over double the stock output.
Power should be slightly better if there aren't extra/tighter bends in it, and transient response will be slightly worse I imagine. Bang for buck it may be a waste, but that's for you to decide. Depends what you plan to use the car for.
Just remember stock boost is only one bar too, you will be running twice that most likely, so the pipes should flow around 50% more air from that alone, and the factory pipes were overkill for stock power.
It will work, but it won't be efficient. Pressure drop through the pipe work alone might be 10psi at a random guess at high flows.
Assuming constant flow, the smaller the pipe will produce an increase in pressure.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
