Hey guys just wondering if anyone can shed some light on a couple of issues I'm having with my 96 S2 R33 turbo manual. I have a weird rattle noise when I accelerate at low rpm. It goes away after say 1500-2000 rpm but anything lower than that doesn't sound very good. It doesn't seem to affect the way it drives but I would still like to determine the problem here. My hicas light does come after going for a drive, stopping for a bit, wand then once the wheel is turned the bloody lights comes on and doesn't go away. Not sure if this has anything to do with it because the rattle noise is always there regardless. Steering isn't affected when the light comes on either, power steering all works fine.
Another problem is that after I accelerate and back off, I get a bit of a bump that almost feels like a push in the back. Kind of like the feeling you get in bumper cars when someone lightly runs into you from behind.
I have no idea if any of these are related at all, but they're issues I want to get sorted out so I'd really appreciate and help or advice you guys can give me!
  • Like 1
Thanks man, I was under the impression that the bump could be diff related. Is there a fix for it or will it need replacing?
As for the rattle, I haven't checked heat shields. To be honest I had no idea where to start with this, I would've thought the rattle would be there all the time not just in the low rpm range if it were that. Any in particular that are more likely to be the culprit?
Chances are you can't hear the rattle after 2000rpm and it could still be there or its due to vibrations at idle and low rpm. Noises are usually very hard to identify just by sound unless its unique.
If you can do more testing and try and eliminate variables it may help. Or getting under the car and putting load on the engine to see what happens.
Can you hear the noise in neutral or just while in gear? Possible heat shields on exhaust or something? Need more information to help you out.
For the 'bump' issue, it could be diff related but can't confirm. Have you serviced the diff recently and checked all the moving parts are alright?
I can't hear the noise in neutral, it only ever happens at low rpm. You can feel a bit of a vibration through the seat but it's not too violent. No feedback or vibration through the gearbox either, that all seems ok!
It's hard to describe the sound, it is what I would expect a loose heat shield to sound like so I'll definitely check that, thanks.
I've only had the car for a couple of months now so I haven't checked out or serviced the diff yet. Still trying to sort out some of the problems that were there when I bought it.
The vibrating you have at low RPM sounds exactly like mine and my mate also has an R33 with the EXACT same rattle. I have tried many things but can't seem to work it out.. If you get help with this I want help too.. Just letting you know that it's not just you having the issue. Also we have the clunking diffs too hahaha.
How annoying is it?! Such a painful sound man haha. There are a few things like the heat shields and rear diff I need to check a bit closer once I have a chance to get it up on some stands. What have you tried so far? Just so I know a few things I can eliminate.
I've also realised I'm missing an exhaust bolt/nut at the top of the dump pipe. Not sure what size these are and I didn't know whether you could use any type of bolt due to the heat it'd have to withstand. Are you missing any as well by chance?
I'm not missing any bolts but I've tried manifold heatshield, Turbo heatshield, bumper, grill etc.. I haven't checked any other heatshields but I noticed my rear engine mount is a bit shot.. Check yours as well to see if there is excessive movement and let me know.
  • 2 months later...
Sorry to drag this thread up again but has anyone had any luck with the rattle? I've checked my heat shields and the transmission mount seems ok.
Still a bit stumped as to what else I should be checking??
Get it on a hoist and start thumping parts to replicate the vibration, if it's exhaust it shouldn't be hard to hear. Run the car on the hoist if it makes the noises at idle, and use the hose in your ear trick to pinpoint where it's coming from.
I've had it up on stands a few times and checked over the exhaust & mounts with no luck. It doesn't affect the way it drives but does vibrate a bit. Only makes the sounds under a bit load in 1st or 2nd usually, so it might be hard to replicate the sound on a hoist as well.
It's doing my head in trying to work out what it could be!
  • 9 months later...
Hey man, ever end up resolving the problem? Mine starting to do the same;
- low rpm noise and vibration
- goes away when boost kicks it/higher rpm
- no noise on idle
- coasting then clutch in still makes noise
- revving in neutral no noise
- revving in gear no noise
- no noise on idle
The rattle that I had was coming from the exhaust heatshield just after the manifold. It's a 2 piece heatshield there if I remember correctly and it was just touching. It would only make the sound when taking of in low rpm.
  • Like 1
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
