Hi guys not sure if this has been covered but I couldn't find much useful info... just wondering if there are any reliable tyre shops preferably Adelaide Northern side or city area, just had a bad run with my regular place as they chipped my brand new rims in a few places, thanks!
https://www.sau.com.au/forums/topic/457006-tyre-shops/
Ray at bobjayne prospect.
honest dudes and good fitters.
always looked after me and did quality work.
they will do what you tell them if you have specific needs or a setup you want too, which is surprisingly hard to find.
https://www.sau.com.au/forums/topic/457006-tyre-shops/#findComment-7541432
I live down south and swear by the blokes at Tyrepower Morphett Vale (used to have the shop at Hackham for those playing at home)
but
my grandfather swore by the blokes at Tyres & More Prospect on prospect road while he was driving small delivery trucks, visited them a few times, very knowledgeable blokes, easy to talk to, very caring of the vehicle and fairly quick service/turn around.
I would certainly recommend them for people around the prospect sort of area.
https://www.sau.com.au/forums/topic/457006-tyre-shops/#findComment-7545883
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
